Ripcord's 2002 4Runner Sport Ed.
The side by side pics are awesome. Now I'm starting to understand color matching your bumper. What a clean, bestial look. I'm not sure if I used bestial correctly, as I'm not trying to imply impure acts with animals, rather how aggressive yet refined your bumper appears to be good sir!
As always
Looks great, I look forward to the painting of the bumper. After seeing all the SC stuff, you guys are making me want to get one on my rig.......punk!!!!
Thanks. It will look better when it has paint. lol
DO IT!
And that's why the Runners get locked in the Garage every night....:wow::guitar3:
Hey awesome 4runner. I was looking around to get some ideas when i came across your build thread and i must say very impressive. I used to have a 99 4runner limited 2wd but sold it awhile back. Looking at getting a 98-02 4x4 this time and plan on lifting it pretty much the same way you did. Some places say the upper control arms are needed others do not. I didnt see that you replaced yours and i was curious if you knew what the advantage was. Also you can run 33's? (285/75r16) with no rub on your setup? and with the brake upgrade did you ever see if the 16 inch rims would work or not? Just trying to get an idea before i get one on the funds i should put aside from selling my truck here soon. Awesome build
Ryan
Ryan
Thanks for the compliments and welcome to the site, Ryan.
UCA rubbage depends on the backspacing of the wheels. 4.5" and less will eliminate UCA rubbing. But any less than 4" will cause frame rubbing at full lock.
HAM Radio Install, K9000 motorized mount
|June 27, 2012|
Today I FINALLY installed my 2M HAM radio. In addition to that, I had a Diamond K9000 motorized antenna so that I could still go in the garage. haha!
Parts:
-Yeasu 1500M 2m HAM radio
-Diamond K9000 Motorized mount (with LRM crossbar mount)
-Diamond Antenna
-DPDT Momentary center-off rocker switch
photobucket-19287-1338404885624.jpg~original
Started with wiring the motorized mount..
The K9000 comes with a pretty ugly switch, so I swapped in a new one.
121_1279.jpg~original
The wiring for the new switch is a bit intimidating, but it really is quite simple.
121_1281.jpg~original
All you do is have the power and ground come in on the two top prongs and cross over to be reversed on the two prongs on the opposite side. Then the leads for the mount motor come off the middle! Its that easy!
Got all the wires tucked away.
123_1284.jpg~original
123_1285.jpg~original
This is where I mounted the new radio, its really the only spot I had left in the truck, haha.
123_1287.jpg~original
123_1293.jpg~original
You hammy sum beech.
Did you sit outside in your driveway till 2am last night trying to talk to people in Hungary? :jk:
That motorized antenna is pretty slick, and I'm sure it's a good feeling to know that if you get into trouble by yourself in the middle of nowhere you can call for help. Nice work!
Thanks man.
I am still trying to figure out all the settings on the radio, but Im sure Ill be able to reach quite far :biggrin2:
I still need to meet up and give you that tensioner plate, tomorrow afternoon?
I've heard you can talk across STATES with those things under the right conditions. I'm curious to see what kind of range you can squeeze out of it.
I've got work tomorrow, but should be home by 6.
Yeah these things have crazy range. I can't wait to try it out.
My work starts before that, so maybe Saturday or Sunday. PM me, lol.
