Post your LIFTED pix here!
Technically not a "lift", but leveled with Bilstein 5100s front and rear. I get asked often if it's lifted, and my wife complains it's too high already- so I guess that sort-of counts?
Front 5100's are set on what setting?
Love it! Would like to know the front lift as well.
Ok so for the sake of not getting smashed for not searching I want to just let everyone know I did a search already on Wheel size and BS etc. I also looked though countless pages on this thread of lifted TR4's. Yes it is possible i missed something.
I am looking for PIC's front view and fitment options. I bought a 2013 SR5 got aftermarket rims through the Deal (bad idea) they are Gears rims 18x9 0 offset 5 BS.
From what I have found that size is run and does fit with no rubbing (size permitting) right now I have 275/65 BFG's which barley fit at full turn to the plastic. Wondering if I screwed the pooch on this one as it seems most are running a -12 offset which kicks the wheel out a little. From what I read this makes a little under 1/2 inch difference in where the wheels sit. Not hudge unless you are looking ro run 33's and do major wheeling which I am not since the wife drives for her daily family rig.
So looking for advise on tire size and front view PIC of a 5th Gen with a similar set up in either 18 or 17 is fine with me. doing research for when I am ready for a lift and new tires.
thanks in advance for the help.
Now I guess I will sit and wait for the responses and hope not to get smashed for searching LOL
:behindsofa:
After all of the reading I did on here trying to figure out what setting to use, I was planning to let everyone know- but then I forgot to ask the shop! They asked me how I wanted it to look, and I said "level". Sorry!
Bilstein 5100s @ .85
. . . and new goodyear silent armors 265/70/17
2012 Lifted 4runner
General Grabber 33 x 12.5 (315/70/17) Tires.
xD Rims
Bilstein 5100 suspension
2.5" lift
AfterMarket Terminals
My Lifted Rig
A work in progress....
xD Rims
2.5" lift
I think 33x12.5" should equate to more of a 305/65R17 rather than a 315/70R17. Regardless your truck looks fantastic with those tires; nice choice!
Very interested to see how 12.5" 33's work on your 5th Gen. Even with a body mount chop, fender well mods and a significant amount of +caster dialed in, 285's seem as big as I can go without rub at full flex and or crank(ie: the more severe offroad situations). Very happy with the roughly 33x11.5" wide ATZ's I'm currently running, but would love a set of true 33's under there.
Looks bad ass I like the stance, what height did you go with in the front? Looks like it was less then the full 3 inches
Thanks. At the moment the front is set at 2.5" so it still has a little front rake. I am not sure if I like it yet or not. Also waiting for it to settle to see where it ends up
Bilstein 5100's front and rear. Daystar rear spacer (1.5"), fronts set to 2.5". Stock tires for now.
So with this no changes to other suspension parts? I assume you have to have it re-aligned? Sounds simple enough that I might be able to do this.
As expected Bilstein 5100's on all 4 corners made a big difference in how it handles on and off road (nothing too extreme).
No other changes. Had alignment done at same visit. For a mechanic, shouldn't be any trouble at all.
