I successfully programmed my new key fob I ordered online from remotes remotes for $50, works like a charm and has the back window button. Looks just like OEM, except no toyo emblem or marking. I bought the truck a few weeks ago and it did not have any key fobs.
Think I figured out my odd noise
Believe my exhaust has finally shit the bed. So now starts my shopping for a whole new system and a resonator delete with angled exit :D
Pretty sure I have a cracked header. When I rev the engine, the leak sounds like the high pitches whirring of a weed whacker. URD time!
Just started brake day!
One picture of my interior LED swap. This was insanely simple! Only complaint is that the LEDs only work one way, and I never got it right the first time....
Daylight contrast is minimal. Cant wait to check it out tonight. Still waiting on my rearview mirror wiring harness and that'll go in next, and am going to attempt the Map Light mod.
Good comparison of the two bulbs!
I wanna do LED interior lighting as well, but I've never been a fan of cool white.
Anyone know the fix for the PAC harness with the JBL and an aftermarket head unit when your rear door speakers don't work?
When on some backcountry trails through our beautiful mountains and got a little dirty!! Took the furry friend along too :) Now I must go wash the dirt off!!
Had a chance to check out the new lights. Huge difference in color. Makes me want to do a dash LED swap and have a full white display...
Oh if only I was rolling in $$$.
Next up: Map Light mod. Can't believe the difference in light that provides.
Went wheeling today and flash flooding was pretty bad through the Mojave river area. I ALMOST got stuck a few times,
IMG_1173_zps5e50611e.jpg~original
it was covered in mud and it took about 2 hours with the pressure washer to get it cleaned. The mud stunk too :puke:
IMG_1175_zps51adaeaf.jpg~original
oh well atleast it cleaned up well.
Looks good both ways! When are you getting a rear bumper?.....:gossip:
Lots of work today! Will try and get pics tomorrow or sometime! Added billies set at 1.75 to front, put in toytec super flexes in rear with daystar 1.5 driver side. Took advantage of lifetime advanced auto cv axles and put some new ones in, added a diff drop kit!
So front end is: FJ coils with bilsteins set at 1.75 with a daystar budget boost topout spacer (inch thick poly, net almost 2")! Some of you will question me, but I have a friend who has similar and has been working great. The measurements for that set up puts the front at 38 1/4 driver side, 37 3/4 on passenger, that 1/2 drives me crazy, may look and see if i can do something. this setup is slightly less than guys running OME's with billies at .85! Everyone that is at that height gets stock UCA's in spec, so that's what will happen for now!
Rear with supers and daystar 1.5 on driver side is: driver 39.25 passenger 38.5! I'm going to run this for a few days and see if it settles, if the 3/4 diff stays I plan to cut the other 1.5 I have down some to make them even. I know some may not care about the .5 and .75 differences but I can see em and they bother me!
