"Base Camp" 2015 Superwhite TE Build Thread
dieck
Just picked up my 2015 Superwhite TE
Had the good fortune to find this forum while preparing for the purchase which means I had mod parts before I had the truck. Will use this to document my mods. Will edit this initial post to keep it current and add detailed mod documentation in future posts.
Custom rear cargo storage with L-track tie downs and flush when seats folded
Custom Rear Cargo Area with L-Track Tie Downs and storage Flush when seats are folded. This has been my most used and favorite mod to the truck. Bomb proof and used almost daily.
Components used in build:
From local HW store:
1/2 inch hardwood plywood for platform and doors
2x4 pine plywood for 3 supports
Stainless 3/8 inch bolts washers and lock washers
From the Interwebs:
Concealed hinges for doors
Recessed handles
L-track logistic tie downs
Tie down l-track adjustable studs
First took measurements and cut 2x4 scrap from other projetcs to fit base. Lined up the outer 2x4 over the under body unibody frame so the tie down points pass through multiple layers of sheetmetal. Middle support is just through 1 sheet of sheet metal. Plan is to have studs over strongest part of body, then to have the L-Track tie down rails directly on top of the bolted down studs.
Then I got a sheet of 1/2 inch hardwood plywood and cut it down to size. Used pencil to mark the layout and cuts. There are two layers of ply in this design. The base layer is all one piece with the holes for the doors cut out, and then there is an upper layer that will be flush with the doors and the L-Track.
This is a detail of the bottom of the thing. It ended up being quite a complex shape to conform to the floor and make the most of the available space.
Here is the top with the rails and doors laying in place. I spent a lot of time thinking about clearances and anticipating the different locations Line-x would be sprayed so everything would be flush and tight (but not too tight) once finally assembled with Line-x
A final test fit in the truck and checking tolerances all around.
Detail of the countersunk doors to allow for the depth of added Line-x on both the doors and the frame.
Sprayed with Line-x. The guys working there thought I was legitimately crazy. But fact of the matter is my 2015 4runner has a higher payload than my 2010 tundra crewmax! Everything came together nicely!
Installed the hinges. I spent some time thinking about them and got them installed correctly the first time. That never happens!!!
Final pics in the truck. Everything's a little dusty.
After living with it now for a couple weeks I couldn't be happier. It's super secure, the tie downs work great! It's really nice to have some concealed storage and the 4 door system allows me to have gear in the back area and still get to one or more doors by moving things around vs 1 big door I originally planned.
I've had several inquiries about it. Feel free to borrow any or all of the design.
Toytec Boss Lift and 255/80R17 Cooper ST MAXX Pizza Cutters
Got the lift installed. Didn't take many/any pics as it was a solo affair. Toytec Boss 3 inch with Light Racing upper control arms. Went with heavy superflex rear springs since I tow an offroad trailer at times. 5 255/80/17 Cooper ST Maxx tires.
Did not install diff drop or radiator mount spacers as it seemed more elegant to just grind down the radiator support for clearance. Has been great so far.
No rubbing at all with proper alignment. Very happy with that.
Dog and Camping trailer
Here I will detail our custom offroad camping and dog trailer
Aluminum tubular chassis and roll cage for dogs
Stainless kennels and exterior
2 100 watt solar panels charging two yellow top deep cycle batteries
Engel refrigerator
Full kitchen w dual burner stove
30 gallon water
40 lbs of propane
3 full size insulated dog kennels with thermostat controlled fan and adjustable ventilation
Remote kennel thermometer
32 inch bfg at e rated tires
Same ground clearance as the 4 runner
More pics and details to come
Congrats on the TE! I, too, am in Austin with a White 4Runner. Let me know if you need help with install on anything or if you need to do any custom settings with the Techstream! I need to get a build thread going myself.
