Fender liner PDF?
Here are the part numbers and prices, courtesy of Greg from toyotapart.com
53735-35150 SEAL, FENDER $16.48 x 1
53886-35020 SEAL, FENDER $17.76 x 2
53736-35150 SEAL, FENDER $20.04 x 1
https://drive.google.com/open?id=0B1UzjUVpNb9jRWlLWVdkR0lydmRpRnpmdlNPMFZ6ZlNnRnNz
Let me know if the link for the pdf doesn't work.
These are for a 2003, but I would expect that the parts are standard through all 4th gens.
What materials are you guys using for the liners?
I used some oil resistant rubber from Grainger (worked great!):
GRAINGER APPROVED Rubber,Vinyl,1/8 In Thick,12 x 24 In - Rubber Sheets and Strips - 1MXU1|360-1/8B - Grainger Industrial Supply
"Oil-resistant Vinyl Rubber, Plain Back, 1/8" Thk, 12" X 24", 80a Durometer "
Part number on grainger.com is: 1MXU1
Some people cut up trash cans and some used trimable floor mats.
Seem my thread below:
http://www.toyota-4runner.org/4th-gen-t4rs/198245-pdfs-4th-gen-fender-liners.html
You could use the backing material from either an old carpeted cargo mat or welcome mat. It's thicker than the factory pieces!
Looking at doing this also. What fasteners did everyone use? I have a couple that will need to be replaced.
Also did anyone have to make adjustments for a body lift?
Best, J4R
Best, J4R
Yeah with the thicker materials are you guys still able to use the stock plastic push pins?
