No I do not live on or near a mountain. I live outside Atlanta.
I have done something similar to this not a lot of success.
I am wondering though could the calipers be part of the issue or maybe the master cylinder seeing as how these are quite a bit larger then what it was designed for.
Have you tried taking the pads out and putting the same ones right back in? Maybe something gets out of whack after a week. If it goes away with the same pads put back in you need to look elsewhere.
Are you saying use same pads and new routers or what is the idea here? Just confused to what you're suggesting to try cause I'm willing to try anything at this point.
You said the problem goes away when you change the pads. Maybe it's the process of changing the pads vs new pads.
I'm suggesting taking the whole brake apart like you're gonna change pads, and then either a) put the same pads back in, b) switch sides with the pads.
Part of troubleshooting is determining if it's the process or the parts causing the issue.
I am wanting to do this mod and I may not have read enough info. just want to be sure the stock 16 inch 5 spoke wheels will clear the tundra calipers
Agreed - Part #SE-3263 & #SE-3264. The powerstop rotors aren't bad either IMO (part #K2324, available on amazon)Napa calipers have a great following here
Best recommendation on where to purchase OEM Tundra calipers for the best price?
My Summer rims:
Winter rims:
looks good. What did you use for caliper paint?
I had some engine enamel in my garage so I used that--- 2 coats, however, as these calipers were quite rusty, I soaked them in Rust Rescue for 48 hours then primed them with Corroseal.
I can tell you the 17" rims (Winter set) were really beaten when I spotted them at the wreckers, they even tried to talk me out of buying them! I got'em cheap! They were a great deal of work. First I stripped them with Lacquer thinner, then ground and sanded the corrosion--- thank god for Dremel! Then I hand sanded them smooth and finished off with steel wool. I applied 2 coats of Aluminum primer and 4 coats of Duplicolor Premium wheel coating, followed by 2 coats of clearcoat.
http://www.toyota-4runner.org/membe...ress...-picture36568-finished-winter-rims.jpg
Rims look great too. I used the same paint on my OEM Tundra rims (on my Tundra) and the paint held up very well. I got some peeling Tacoma rims with snow tires for winter that I need to try and strip and paint. What color did you go with? I think that would look good on a black truck.
