Post your LIFTED pix here!
If you don't mind me asking, how much did that lift cost? I'm bought a '16 and like the look of yours. What rack is that too?
Bilstein 1.75 + Cornfed 1" / XD Revolver Rims & 275/65/18 KO2's
Man that looks great! Would you have any side pics to see how the wheel gap looks?
Show's the front - the back is about an inch higher
Thanks to a couple threads here, I was able to get my Toytec 3" lift and LR UCAs installed. I did the front yesterday afternoon and the rear this morning. Because of the great write-up from eddiebx and advice found from Antman, the job was relatively easy all around. It helps working on a newer vehicle that has not rusted anywhere too! I only need to get the alignment done but I think I'm close using string, measuring tape and levels.
Finally got everything on. King coilovers, King rear shocks, Total Chaos UCAs, Icon 2" coils, and 285/70R17 BFG All Terrain KO2s.
Installed 5100's frond and back w/ Icon rear springs and went straight to George Washington National Park. Everything else stock.
Yes, it is just 285s and 5100s w/ stock springs and rims.
The new Trails look really good already (besides the lame tires they put on them and the 2.75" back to front rack). The front is set on the 3rd ring (~ 2"lift). I tried to keep it simple, but now I just want to keep adding stuff now :-).
Hey [MENTION=114962]dtcarlso[/MENTION] Sweet Super White Trail! I believe you meant to say that you have a 1.75'' Front Lift & Stock Rear like the picture below.
Toytec lift with LR UCAs... the ride is a little stiffer than OEM but for me that is great because the OEM ride was too soft.
I had it aligned yesterday as well. With my measuring tape and level, I had castor and camber spot on. I only missed on toe! Not too shabby for an amateur! Bagheera tracks straight now!
