LawnDart
Haha. I actually had to google that! But I'm glad YOU know about it. Jealous much?
well he does live on that side of the river....
hahahahaha! No!
"Just because I don't care doesn't mean I don't understand." - Homer Simpson.
hahahahaha! No!
Did you use any sealer or silicone to install your K9 rack? Plan on installing mine next week. Also did your RTT mount right up in the rack or did you need anything special?
[MENTION=136795]Irishcav17[/MENTION] I used to use the wind deflector. I took it off because i'm going to be mounting a light bar up there. If i wasn't i would have the delflector up there.
Lots of updates so little time. As [MENTION=68685]Ducmonsta[/MENTION] mentioned i did put in some sound deadening throughout the entire truck. Thanks to [MENTION=65614]Antman[/MENTION] for the tip on using roofing material. That roofing material from Home Depot did wonders for the sound and feel in the cabin. I put down 2-3 layers on every door and the entire trunk area. It's really quite in the cabin now and the stock system sounds at least 5x better. Bass is way more pronounced now. You can definitely feel it much more.
The doors sound like their European when opened or closed. Just pulling the handle to open the door made a huge difference in sound and feel. I would recommend everyone do this pretty simple mod. You will love the new feel of your interior.
Looks great, I still want to run an airchuck out to the rear bumper on mine.
Are you going to run the line under your rig or through the inside?
Is that the six position v series?Here is my switch panel that [MENTION=68685]Ducmonsta[/MENTION] and I installed. I used OTRATTW switches with their housings and gutted out that little pocket in the center console. I also have a Blue Sea 12 circuit fuse box up front under the engine bay and a Blue Sea 6 circuit fuse box in the rear that has the constant 12v to power my fridge and charge cameras/phones/etc. Pretty happy with how all of this is working out.
