4Runner alternator upgrade (gen 5)
Hi Adam,
You're doing things the The RIGHT way! Myself (OTOH) discovered that I needed a generator upgrade after seeing the symptoms of an alternator that just couldn't keep up e.g. headlight pulsation, temperature control blower and wiper motors slowing down...etc. I'm very much looking fwd to seeing (reading about) your finished product!
Because you're adding approximately 100A to your existing main electrical system cables, I would strongly recommend adding an additional (POS) Alternator output (B+ term) to positive battery terminal post and (NEG) battery cables; main negative battery post to body, and an engine to body cable:
rigtec-albums-%26quot%3Bgentilmen+prefer+redheads%26quot%3B-picture26784-all-cell-pix-june-2014-012.jpg
The dotted lines represent the existing factory cables, which I've left in place. The solid lines illustrate the new, heavier 4ga cables that were installed.
Don't worry about the body to frame (chassis) cable; there will be no additional or excessive loads added to that circuit!
'Best to you'!
Thanks [MENTION=83083]rigtec[/MENTION]! Alternator is in and working flawlessly. I did exactly as your schematic illustrates with a ground from engine to chassis and a secondary positive. The Northstar Group 31 is a beast and now is getting charged when I am just idling. I put the battery on a charger last evening to be sure it was 100% prior to alt install.
If anyone is looking to do this upgrade I highly suggest contacting Nations Alternator and ask for Adam. He will take care of you!
I definitely love this post... another satisfied customer!
PS: You didn't mention the Negative battery post to body cable; ALL of the current that leaves the positive battery post & alternator B+ term has to come back through that neg battery cable/post; potentially over 200A! So i would definitely add an additional 4ga cable along side the factory negative! GOOD JOB!
rig
Oh I did add that as well. It's all good. It is amazing how well everything works with an abundance of charge. The engine starts up so quickly.
Hi there again folks,
There's been a Major Buzz around these parts lately; and for a very good reason! A very knowledgeable senior member; a gentleman who's work I've admired here on this site, and over on The Toyota 120 Platforms [MENTION=55815]Okki[/MENTION] (AKA Paul)! He's decided to open a door over at Nations Starter and Alternator so we might all be able to afford the highly acclaimed DC Power Engineering 270-XP alternator. He's had a tremendous amount of progress over there with them. He's got their ear, giving us a voice, gathered a high number of our members and is cutting a deal that no one (Here or there) will be able to turn down!
So I've got my sleeves rolled up and will do whatever he asks me to do so we can get this ($690 dollar) 270 ampere alternator for a price that's more than affordable; Thanks Paul! Anyway while reading his thread: http://www.toyota-4runner.org/5th-g...y-dc-power-engineering-270amp-alternator.html I received a couple of questions about This alternator, the way it works, what kind of voltage can we expect from it, will it have an affect (good or bad) on our ECU/PCMs and other great Questions like that!
So I wanted to address some of these questions (w/o taking his thread O/T) and to give those of you who want to participate in the group buy; or even if you're not quite ready to take the plunge right now, but just would like to research the subject a little further, I think that's a great idea! When I bought my 270-XP, I spent much time asking myself questions then in turn I would go to different sources and immerse myself in all of that wonderful information that I found out there... I'm the kind of guy who doesn't like surprises (NONE of them are good lol!), so before I ordered my new alternator, I wanted to know what's so different about this aftermarket alternator... they're all the same right??? ...well, no they're not, not at all!
Most of the alternators that you see advertised as 'The BEAST' or 'godzilla' or 100 other names that are just gimmicks designed to grab your attention cannot do what you think they can do. Not because the company lied and told you that it can deliver 590 amps. But in their advertising that you saw it was implied and it was stated in such a way that they let you fill-in the blanks, so you concluded that this product will develop 590A to run an unlimited amount of accessories! I totally believe in the spec sheet. I also believe in gathering the full meaning of all of those 'Weasel words' that mean NOTHING but are just there to make you believe that everyone else except you all know what those words mean; but you're afraid to ask anyone on the forum what that means because you think that everyone may laugh at you and then we'll think you're stupid... RIGHT?
That's the reason that I love to study! It helps to expose those wives tales, folklore, myth, fairy tales and just plain-ole' "Spooky bull-ship"! I'm gonna try and keep this post short (it'll be a first). A question was brought up the other day wrt ECU/PCM controlled voltage in some of the newer vehicles being built right now and so I wanted to talk about that briefly! I needed to know this too because I had just ordered the 270xp and was hoping to get a full 14.00 volts from it; that's one of the things that I didn't like about my 2012 limited 4Runner. I mean I guess 13.2 is okay if that's where the factory had set it, but I just couldn't help being a bit... disappointed about that; after all this was to be a rescue vehicle for my family and close friends in the winter; NJ gets snow like Boston used to get back in the day, 30 inches every 14 days is no longer strange these days!
So, what is all this stuff about PCM controlled alternators, and what would be the benefit? To keep it short... it's about fuel economy and longer battery life! Theory is: generating electricity puts more drag on the crankshaft and so the engine must consume more fuel to spin the alternator. So the mechanical engineers decided to find ways to decrease the amount of drag that it takes to turn the alternators pulley as often as it's not needed to work so hard. To start, they set the alternator to develop a maximum output voltage of 15 vdc. Next, they installed a voltage regulator that would prevent the alternator from going anywhere near 15VDC, but instead, they decided that 13.5 volts would be sufficient to run every accessory that the truck would feature... and then some!
The next thing that Toyota decided to do was to create a 'fuel saving option' that would be able to over-ride the alternator's voltage regulator under specific conditions e.g. when it was really hot out. It is at this particular time when the ambient temperatures are elevated that the battery is most vulnerable to an over charge condition which will shorten the (Standard lead) battery's anticipated life span. So the electrical architects/designers decided that PCM could over-ride the internal voltage regulator under certain conditions. So now the PCM Controlled Alternator would have more than one advantage over the 'Stand-Alone', self contained alternator. When the conditions are just right, the PCM (a calculating computer) will make decisions wrt how much of a charge the battery will need based on what accessories are on, outdoor temperature...etc
Even though the PCM is allowed to limit the MAX voltage output of the alternator, the Internal voltage regulator acts like a safety device and will prohibit any voltage output above a pre-determined set-point to protect the more critical electronics e.g. ECU, PCM, Instrument cluster, canBUS system...etc! So the PCM does have it's function in the Fuel consumption domain, and as the Battery life span manager. Even though I was glad that I had learned some important facts about ECU/PCM function, I was glad that the 5'th gen 4Runner doesn't use the fuel consumption PCM to control the Alternator but rather, monitors (M terminal for Monitor) the use of our electrical system to create a history log, and perhaps to determine when/if a battery is constantly being replaced, just what the cause might be!
Now fast fwd: When I had just dropped my new 270-XP in I was ALMOST afraid to look at the output voltage for fear that the PCM may have been controlling the output instead of only monitoring it; I had spent some time on the phone speaking with the sales rep to be sure that the 270-XP would be totally independent wrt the output voltage; I didn't mind that the alternator and electrical system were being monitored for the sake of impropriety, but I knew that I needed to see 14.05 at all speeds and even at curb-side idle while using every electrical accessory available. But all of my research had paid off! I was seeing a constant 14.12V at the battery posts and I could load it up e.g., Both JL Audio HD-750s were being pushed for the sake of this test, temp control blower on HIGH BLOW, windshield wipers on high (front and rear) all lights were on, heated seats, A/C, rear defogger grid... and this was before I added the three heavy auxiliary cables (The BIG Three) to provide a multiple path electrical carrier grid! For those of you that are planning to install the 270-XP to your truck, it's a great investment! For those of you who are on the fence, I say take your time and don't buy before you feel that this is right for you! Thanks so much for reading this post,
rigtec, 'Best to you'!
SORRY, COULDN'T RESIST! Courtesy of [MENTION=133889]smkymntn[/MENTION]: another satisfied customer!
Cheers
Great write up rigtec. If you are at all like me( and since you're on t4r you are) you want to know that every upgrade you do will either enhance or improve your vehicle. I was nervous after my 270xp install. I hoped it would be everything I was looking for which was to never worry about my alternator keeping up with stereo, lights and whatever else I decide to put on in the future. I went the added insurance of installing a group 31 Northstar battery. Before I switched the alternator it would not get a proper charge. After install it is always at perfect operating voltage. Don't trust your scangauge for voltage. To see properly it must be measure at post like rigtec said. This is one of my favorite mods as I know I never have to think about it working. It is a beast
"...This is one of my favorite mods as I know I never have to think about it working. It is a beast"
Same here smkymntn, this is without a doubt, thee' best investment that I have ever made!
PS: Almost forgot to mention: for those of you who may (for whatever reason), need more than 270 amperes to run your equipment, there's a 380-XP made by DC Power Engineering; for the Certified OCD man lol! And, just in case you didn't see my earlier post, there is an available XP Series H.O. alternator with an EXTERNAL voltage regulator that can be adjusted the way that you want it to be set up; just be warned: Be mindful of your lights, electric motors, PCM/ECUs and CANbus systems...14.5v is about the most that they will like so be careful!
rig
Hi [MENTION=144249]SFNMRunner[/MENTION],
I've already spoken to the CSR, Holly about that fitment issue. Here's the Model# for the GEN-5 4Runner: NSA-11517-270XP The Phone# is: 573-334-2632 You can speak to Holly or Adam and you'll be very satisfied with the way they handle your order!
Cheers!
Cheers!
Thanks!
I'm getting psyched!
Why you say... Oh, that's just because a whole bunch of you (could there be 40 or 50 of you?) will be putting in those 270-XP's H.O. Alternators soon, right? So that means that some of you will be installing new electrical accessories e.g., lighting systems, audio add-ons, winches, sub-panels...etc! Well for those of you who love to design electrical systems, plot special operating schemes, or just make electrical stuff work as much as I do, then you'll understand that, this means it's getting ready to get real busy on this forum soon and I'm looking fwd to all of that new activity!
:usa2:...So glad that I'm not the only "circus freak" around here that has a H.O. alternator anymore! :usa2:
'Best to you all'!
:yo: rig
I meant to inquire...
I thought it would be nice if you could tell the rest of us, those of you who participated in the 270A group buy, what will you do to your 4Runner that you wouldn't (couldn't) do with the stock 130A alternator? Would you mind telling the rest of the forum community a bit about your electrical system objectives? I think it would be a great time to share some of your most original ideas; if you can!
Best to you, rigtec
Hey tech team,
I thought that it might be helpful to those of you who will be installing the new 270-XP's in the very near future, so I'm putting up a few help sheets to make finding the GEN-5 alternator bolt location and other generator related intel a little easier; "See below":
There are three bolts that anchor the alternator to the engine; the two up top that go through the 'ears' on the frame, but then there's the third bolt underneath which is impossible to see from up top. For that one you'll have to turn the wheel and get at it through the left front wheelwell using a long ratchet extension! This job may take two to three hours depending on your tools, the space that you're working with, and your own comfort level with the truck!
Above is a picture of that bastard bolt through the bracket which anchors to the exhaust manifold! Just remove it and throw it away; there's no provision for it in your new 270-XP, it's just not necessary!
'Best to you'!
Hey folks,
Here, I'm posting an Electrical Symbol guide! I realize that some of you are just being introduced to the auto-electrical field due to so many mods and opportunities that have become available now. So I want to provide any tools that I find helpful to you so you won't become squeamish or start to shy away from the electrical aspect of working on your trucks! Please allow me to be the first to tell you... you need never be intimidated or afraid of electrical systems; only respect it because if you become careless, electricity can do damage to the equipment, the wiring, and if the voltage is high enough it can ruin your day... ask me how I know lol! Here are some standard electrical symbols for you to familiarize yourself with so when you look at some of these wiring diagrams that are floating around this forum, you won't be alarmed at their (sometimes) complexity:
rig, 'Best!
Hey folks,
rig, 'Best!
[MENTION=83083]rigtec[/MENTION]: I am extremely thankful for your willingness to help us eclectically challenged folks out. Your level of kindness does not go without my sincere gratitude! Thank you!!!
Hi bimrunner,
Thanks so much for the kind words, you can't know what that means to me!
BTW: Words like yours allow me to keep it up! :hatsoff:
rig, 'Best to you and yours'!
NOTICE:
Should anyone need assistance with your Alternators, electrical issues, or just electrical diagrams, let me know: I have them all for your GEN-5 trucks, so you can MENTION (@ rigtec) in your posts, or hit me with a PM (for more discrete assistance)!
rig
