DDM Tuning Saber LED for DRL / High
Guys,
I have to say I've used both suppliers before and can't speak "higher" then one over the other...
Myself being in "wholesale" sales... Sometime your paying for a name, and sometimes not...
I've used DDM HID kits now for the last 6yrs in various rigs and never had an issue with any of them. The customer service has been top notch...
That said when it came time to put HID's in the runner I opted to try TRS and the Morimoto's to see what they where all about...
Both work great and honestly I can't tell you if one is "better" then the other.... I'm sure someone could argue ballast, color temp ect between the two. But both brands have performed flawless.
I'm curious also to see what TRS has to offer and if the kit provides similar or different results.
-A
Ok guys/gals,
This is what I have since receiving my DDM Tuner Saber LED's today.
First, here is a photo of some Morimoto XB LED's I had previously installed on my T4R and was not quite satisfied with the performance, but that is not why I am referencing them here.
The reason I am referencing them is because they were oriented to fit in the 9005 socket and have the LED's at the 12 & 6 O'clock positions. The LED's could not be moved on the fixture, I will explain later.
See Photo:
152116d1428112940-anyone-has-actual-experience-trs-morimoto-xb-led-headlight-drl-highbeam-trs-morimoto-xb-led-headlight-installed.jpg
I received the Sabers and found them to have a set screw between the socket tabs and the fan. These can fit H10, 9005 & 9006 so I assume one may need to adjust which direction the LED's face or oriented depending upon the reflector.
When loosening the Allen screw and turning the fan while holding the socket tabs, one can face the LED's however one chooses. (Remember I said I would explain later :D)
So, one LED fixture was set to be at 12 & 6 O'clock and the other one was set to be at 9 & 3 O'clock.....
Being that the previous Morimoto's were made for 9005 sockets and faced 12 & 6 O'clock, I rotated the passenger side Saber fixture to that position and locked the Allen screw down.
Install complete after zip tying the small ballast for the LED's.
Color and intensity is superb IMHO. Output exceeds the 9011 MOD High Beam!
Mind numbing, mosquito singeing bright which a dusting of the suns rays!
In the following photos, I disabled the LOW BEAMS so they would not come on and ran a comparison.
Excuse the grainy photos taken from my iPhone.
EDITED: See Post # 58
Photos in this order:
LED Drivers Side/ 9011 Passenger Side
Next 2 photos are of the high beams only
Proper orientation of LED in housing (Edited)
Side view of Low & High Beams on (Edited)
Now you've got me thinking of the rotation and led direction would in fact change the beam pattern in our reflectors....
Hummnnnn....
Told ya the high beam was impressive ;-)
Ok guys/gals,
See Photo:
The very last photo is with low and high beams operating, photo taken from the side of reflector.
Side view of the drivers side LED position in housing
Low and high beams operating, photo taken from the side
Stoked to get mine in. Took 7 days but its at least finally in the US. Hopefully it wont take too much longer to get to Louisiana.
I was told by DDM in Cali, if you call them directly and place an order, they ship directly from there.
If you use the online ordering, the orders are fulfilled in China, that is why they take so long to receive.
Not trying to thread jack. But I just spoke to retrofit source today and they are releasing a morimoto version that can handle two pulse voltage for theirs as well. It should be releasing in next couple weeks. Im going to wait to see their version as I like morimoto brand more than ddm tuning.
Sent from my SM-N910T using Tapatalk
[MENTION=139814]nerfkhat[/MENTION],
Ok, you got my attention...
Did TRS give any other specifics?
Lumens, amp/watt draw, price point, etc...
No info on led but they said it will be around the xb led price point which is around 120ish? I didn't ask specifics on wattage or draw.
I called TRS yesterday to get more info on these MORIMOTO 2 STROKE LED's that will become available in about 1 month.
Here are the particulars and photos supplied and they said I could "leak" them.
Will work with Low beam Projectors and DRL/High beams in halogen reflector like our T4R's.
DRL's run at 5 Volts and High Beams run at full Voltage. (don't remember if he told me amps/watts)
They are equipped with fans
3500'ish Lumens
100.00-120.00 retail (without discount)
Ahhh. That makes sense. Was wondering how you got yours so much quicker. Ahh well, gives me time to install the Aiden Customs DRL.
3500'ish Lumens
Damn that's awesome. Wish they could be released sooner. I have wholesale discount too. So if any of you guys like to purchase I could give you a good price and drop ship them to you.
Hummnnnn....
[MENTION=107788]Trail-AMMO[/MENTION],
I turned my LED's 90 degrees (like yours) to check the difference in output....
And......
Just preliminary test in my garage, I am not getting near the light scatter upward and downward now. Which I think is a good thing.
Real time testing on the back roads will generate a better comparison.
I just looked at another manufacturers bulbs (VLEDS) and for their
LMZ PLATINUM 45W ULTRA OUTPUT LED 9005's, they recommend the following:
When I installed mine I was also curious how to the orientation but assumed since the reflector shape on our 5th gens seems to be more spread left and right I'd want the LED's to face as such at 9 and 3...
Now if we had more circular or cup shaped reflectors it prob wouldn't matter at all...
I'm sticking with mine at 9 and 3.
Have you been running them as DRL also?
-A
-A
I have yet to try them on the back roads, yet.
I'm in agreement on the possible best orientation being 9/3. (TBD)
My DRL's are disabled.... link in my Sig.
Copy that.
Just curious your thoughts on the lower wattage intensity...
-A
What a Difference!
Latest Update........
What a difference the orientation of the LED's made in my housings!
Thanks [MENTION=107788]Trail-AMMO[/MENTION], you had it correct from the start.
After turning my LED's to 9 / 3 O'clock position, they throw light forward considerably farther down the road and still get the flood that high beams should throw.
This has got to be one of the best lighting upgrades, save the LED LIGHT BAR!
Glad Trail-AMMO had his turned in this manner and glad I ran across the VLED's description of how to face the LED's!
I suggest anyone that installs these, turn them to this 9 / 3 o'clock position to achieve maximum forward light output from your LED's.
Pretty dang amazing how fast the LED technology is moving isn't it? 2 diodes in each "bulb" I swear it's HID LED with a ballast.
The other night we had a skunk in our back yard and my go to surefire LED on the bed side and it was acting like it needed new batteries..(strobe). So into the safe I go, and pull out a pistol mounted surefire (LED) that I bought maybe around early 2000's... At the time I remember how bright that was, but after using it to spot light that skunk man o man.... We have come along ways.
Copy that.
-A
What are your thoughts as for DRLs. I see the hyperflash, but it's not that noticeable. Debating on disabling DRLs though.
Haven't gotten to use high beams yet but plan on testing tonight. So far I'm loving the brightness from what I'm could tell and the color temperature
