RysiuM
My install of 28 inch 145W LED Bar (14k lumen) and Accessory Fuse Box (with pictures)
Like I wrote in my thread "My version of Interior LED lights" I decided to add more LED to my 4R. I bought 28 inch LED bar of Ebay. There were few selling points for me (besides the price):
- It is exactly 725mm long (28.5inch) so it will fit behind upper grill without any cuts.
- It mounts from the bottom (not from sides) so all the width is used for light, not mounting.
- The bottom mounts are very low, so I can mount it to original metal plate behind the grill.
- It uses lenses instead of reflectors so the focus is really good.
No false claims about the light output from this seller (US located) and the real measured power (145W at 12V) is quite close to advertised 180W. I don't expect magic, but from calculations I think it will give around 14k lumens.
Of course I can't say anything about durability or water resistance - time will tell. The whole lamp looks quite solid and rust proof - all parts are either aluminum or stainless steel. The lamp came with wire harness which I will salvage for parts as I want clean "factory like" installation - similar to what I did with OSRAM LEDFOG101. But that will be later. For now the mechanical installation.
So here is what I saw on Ebay before I put my money on:
And this is the real thing on garage floor just before the installation
Step 1 - Mechanical installation
I like the way this lamp is mounted. There are three metal "sliders" screwed to the lamp case via two M5 bolts each. The slider can be bolted to a car with 1 M8 bolt each. Of course all bolts, nuts and washers are stainless steel.
This mounting puts the lamp very close to the mounting base, so lamp will fit below Toyota emblem.
I drilled two 8mm holes in grill bracket (the third slider will not be used) one on each side.
Because this brill bracket was actually lower than I expected so I replaced M8 bolts with new, longer ones and I made 2 derlin spacers. I know that they are ugly white, but they are hidden between slider and the grill bracket and nobody will ever see them there.
Now lamp is bolted to the grill bracket with lock washer and nylon insert nut. Just to be sure it does not vibrate loose.
Looking from the top is nicely hidden behind the grill out of the way leaving still a lot of space between the grill and radiator if I need to do something there. Notice on the picture, the lamp takes all the width of the upper grill all the way to the air ducts. 30 inch light bar would not fit there without cutting air ducts.
Actually because the lamp is one big block of aluminum it enforced the grill bracket so it feel much sold now. Lamp aligning screws are easy accessible from behind so it will make the aiming process very easy.
So the only alteration to the truck was drilling two 8mm holes in metal grill bracket. Other than that the installation is 100% reversible a and took me about an hour to complete. I know I will loose some light that is blocked by Toyota emblem at the center, but I have 14000 lumens to spare, so if I get only 12000 I will still be very happy.
Here is the picture of the light bar installed and how it looks from the outside. Actually it doesn't look at all as it is hardly visible. But anyway here are these closeup pictures:
This concludes step 1 - Mechanical installation
Now the electrical installation is the next step. To be continued...
