Installed Billies on the front. Set at 1.75" (3rd notch). Leveled the truck out nicely. $210 with shipping on Amazon, installed them myself which only took 2 hours, then $80 for an alignment.
Used the non-spring-compressor method. For those interested:
-jack front end up on stands
-undo front bumper cover/skid plate to have better assess to LCA cam/bolts
-remove tire
-take note of spring orientation (I took a picture for reference)
-place stand on rear frame opposite the tire you are working on
-jack up LCA to apply pressure to strut
-undo strut retainer on top of strut
-undo lower ball joint bolts (2)
-Mark position of LCA alignment cams
-loosen LCA bolts
-allow pressure out of jack so spring decompresses (carefully)
-remove lower strut bolt
-remove strut/coil out of the bottom
-assemble and install new strut replicating spring location and orientation that was previously on the truck
-do all of above steps in reverse to reassemble
-**apply red LocTite or equivalent to lower ball joint bolts when putting everything back together**
-go get alignment
I was skeptical about this method. When I let the pressure out of the jack holding up the loaded piston I was actually hiding behind my garbage can in case something went horrible wrong. But everything went amazingly smooth. The only snafu I had was when I was trying to giggle the LCA down, my had was grabbing the UCA and the spring came unseated and jammed my finger between it and the UCA. Other than that, happy with my now leveled out T4R.
