Finally here: my 2016 SuperWhite 'TRD Trail' w/KDSS
KDSS 'lean' issue: mostly solved
Still have the pax-side lean issue to get around (yes, it's currently out-of-spec by about 0.5-inch), but I'm pretty sure I've found the fix, and I'll update here if it works.
Regarding the KDSS lean issue, several people have PM'd me with questions about it, so thought I should document the relatively successful fix here.
Measuring fender heights at the center of the axle on level ground, as delivered my 'TRD Trail' measured:
  • 1.5" high on the front-left
  • 1.2" high on the rear-left
That is far beyond Toyota's KDSS calibration limit of 0.787 inches, and it was visually obvious looking at the vehicle (see first image of delivery, and the second of the rear of it sitting in the garage). The service tech performed the KDSS lean calibration after noticing the lean, but it really did nothing.
That same day I walked out on the lot and measured all three stock KDSS vehicles they had on the lot, and they all measured about 3/4" high on the left-front, and about 1/2" high on the left-rear; this is an odd feature (or bug) of the KDSS system, that it, in and of itself, reverses the lean compared to non-KDSS vehicles.
Anyway, after a lot of research here on left/right leans with KDSS/non-KDSS vehicles (i.e. KDSS vehicles tend to be high on the left, non-KDSS vehicles tend to be a bit high on the right), I decided that the TRD Pro shocks being asymmetric must be exacerbating the 'normal' KDSS lean (i.e. the left shock is pre-loaded by 1/2" to supposedly compensate for the 'normal' 4Runner's left lean due to fuel/driver weight).
I thus requested the dealer swap the L-R shocks on their nickel, and accepted the responsibility if it didn't fix the problem (i.e. it was the dealer's last attempt to fix it, being that the TRD Pro suspension is not recommended for the Trail with KDSS). Fortunately for me, it has leveled the vehicle to near specs (roughly), and it now leans to the other side, but it is now not visually noticeable:
  • 0.9" high on the front-right
  • 0.6" high on the rear-right
Now, when approaching my vehicle from virtually any angle, I do not notice it leaning, so despite it being near the max tolerance in the front-right, it's close enough for me (and I'm the guy who straightens pictures in the house all the time).
For those of you who noticed the rather large change that simply switching the shocks in the front made, I'm as puzzled as anyone that it effectively changed the lean nearly twice what I expected, i.e. a net change of 2.4" in the front and 1.8" inches in the rear, especially given the fact that no changes were made to the rear whatsoever (the TRD rear shocks are identical). The OEM shocks that were removed, both front and rear, are identical to each other.
After this endeavor, it's my belief that the KDSS system somehow levels itself front-to-rear, based upon some initial (pressure?) set point that it seems to 'like', the calibrating of which seems to make little difference. The system effectively 'knew' that the front had become higher on the right, and self-adjusted the rear to also be high on the right. I suppose considering what the system is supposed to do for high-speed driving, it makes sense that it would do this, despite me not being able to technically explain it.
If anyone were to do this again, I'd suggest either:
  • Switching left and right shocks from the get-go; or
  • Buying two right shocks (no change in the stock perch setting), which I believe would nearly level the vehicle perfectly. Being that the only reasonable way to have TRD Pro suspension is to buy the $1700 front-rear kit, this probably isn't an option for anyone unless they buy the front and rear shocks separately, which would be prohibitively expensive; or
  • Last option would be to move the perch setting on the left shock to be equal to the right, though not sure how difficult this would be.
Hope this helps someone who may go down the 'TRD Trail' road in the future.
Awesome. My TRD Pro suspension was delivered yesterday. I ordered it online from Olathe Toyota (Toyota Parts Online | Olathe Toyota Parts Center) for $1,529.15. It did not come with instructions, so I called and asked if they had any. They did and promptly emailed me the PDF. Hopefully I'll have my local shop, Virginia Solar Tinting (tint, car window tinting, window tinting in richmond va, tinting, richmond tint companies, tint companies - richmond, va) install the lift within the week. Thank you for all of the information!
2016 Toyota 4Runner Trail Premium in Barcelona Red w/KDSS and full TRD Pro interior and exterior cosmetics.
I think I might do exactly as you have done but I am not very interested in true off-roading or TRD look and badging. I have convinced myself -- via reading -- that KDSS is worthwhile and wonder why .. if it is very worthwhile.. why they'd not put it on the TRD. Any comment on this appreciated ! It is hard for the average brain to think through why they have all these varying options. Thankyou.
My belief is that Toyota chose not to put the KDSS system into the TRD Pro for one reason, and one reason only: $$$. It was likely a marketing decision based upon pretty a pretty solid belief that they'd easily sell every TRD Pro they made, and at the inflated price it sells for, they are making more money leaving it out, and keeping the vehicle a bit more (cough!) affordable.
The funny part is that it is precisely the TRD Pro that should have had KDSS, as no one in their right mind would buy a TRD Pro only to remove the (overpriced, but capable) suspension and lift it, the primary thing people try to avoid--or get talked out of--with KDSS vehicles. Being an out-of-the-box, only-slightly-more-capable vehicle than the Trail or SR5, the TRD Pro is for people that don't necessarily want to excessively mod their vehicle, which is exactly where I think KDSS fits into the market.
Of course, that's just my opinion. ;)
Smitty BeaverStep
Got the Smittybuilt BeaverStep installed recently. Instead of cutting strips of 'grip tape' (old skateboard term ;), I penciled out a template and cut one piece to fit.
Liking having this thing on the rear, as I'm pretty sure it would take most of the brunt of any minor rear-end, which seems to be getting more and more common these days with distracted driving.
Cheers!
KDSS skid fairing cutout
Also recently got the stock plastic KDSS skid fairing cut to fit the TRD skidplate. I took a couple of on-offs to get it cut just right, but easy to do, and hopefully will keep some of the winter road crap from entering and plastering the bottom of the radiator.
Looks great! Curious why the "ceramic" tint? What makes it different/better than other tint? I have no idea about anything tint related and this was the first time I had read about ceramic.
Cuts a substantial amount of heat while still allowing the light to pass through.
Good to know. Starting to google it now. That is the first thing I am getting done to mine. Do you remember what % you went with?
Dealer never actually gave me the specs, but it photographs to be 3-4% lighter than the rear windows. Odd, because visually it appears darker to me when looking out the windows.
I was as close as you could get to ordering a trd off-road to build like this vs the pro. As much as I do like a sunroof and kdss sounds like a nice feature, I opted out based on my experience with my 07. I've been through two sunroofs on it (loud grinding gears first, then leaks) and we all know the issues xreas folks had with leaks etc. They still use the same sunroof design on the 5th gen and adding hydraulics to a sway bar just seemed like it would be a head ache down the road. Played it safe and went with the pro.
Great thread. Great truck. This is the direction I'll be going. Unless they announce new gen 4R for 2018. If not, I'll be building this same way. Thanks for the info on the lean, too!
How would you describe the feel of the suspension? If you've driven the pro, is there any difference in ride quality? What about vs stock?
