I don't know if that would work, because with the design of these shocks, you need to keep the spindle from turning with either an allen wrench or crescent wrench depending on the type of shock you're installing. Because of this design, you need to get your hand in there with an open end or preferably a ratcheting wrench to tighten the nut while the allen wrench or crescent wrench is resting against the frame keeping the spindle from turning.
So, since you have an allen or crescent wrench on the top of the spindle, you can't use a socket to tighten the shock spindle nut. This means you'd need to cut a hole in your floor board large enough for you to fit your hand through. That'd be a big mofo hole. I doubt you wan't to carve your floor board up like that.
Yes, it's a pain in the ass to remove and replace rear shocks. But, if you have the right tools, it's tolerable. The best advice I can give is use a ratcheting wrench for this job. The first time I replaced shocks I used a basic open end wrench to tighten the spindle nuts and I was exhausted by the time I got both shocks installed. It was a serious test of my patience but a lesson in how much easier a job can be when you have the right tools. I now have a full set of ratcheting wrenches made by Gear Wrench.
Simpler, but more work= more time.Or you could just drop the frame, makes it SO much simpler :bounce:
IYes, it's a pain in the ass to remove and replace rear shocks. But, if you have the right tools, it's tolerable. The best advice I can give is use a ratcheting wrench for this job. The first time I replaced shocks I used a basic open end wrench to tighten the spindle nuts and I was exhausted by the time I got both shocks installed. It was a serious test of my patience but a lesson in how much easier a job can be when you have the right tools. I now have a full set of ratcheting wrenches made by Gear Wrench.
<iframe width="560" height="315" src="https://www.youtube.com/embed/N5fAXAuGozI" frameborder="0" allowfullscreen></iframe>
How long do u think it took u to do this job...
I really think 5 hours is a reasonable time for someone to do this if they have all the tools and info available to them and there's no guesswork.
I think that's a pretty fair time. It took me 4 hours with a lot of coffee breaks in between. Another 15 minutes to test drive it and another 10 minutes of watching my rear main leak after the drive. I don't know if I've ever looked at an oil leak with such hatred. I was really hoping it was the valve covers. :ybrick:
I was serious about the offer to help pull your trans to do the rear main seal. But, knowing how much work is involved, I guess the oil leak would have to be pretty bad to warrant going in there. However, it would be an awesome DIY video to make.![]()
Next project is the steering rack guide and then a cotter pin in the steering slip joint. I still have this ever so slight vibration at 50-60 that's annoying the shit out of me. Only me though, my wife can't even tell it's there. lol
What about doing the tack weld technique for the steering slip joint? Seems like that might be a better fix for that play.
BTW, I swear a lot too but I've had to control myself when making the videos. We could just shut the camera off and swear like a couple drunk sailors or dudes with a bad case of turrets when something is fighting us and then restart the camera when we've gotten all the frustration out.
That picture makes it look easy.
Yes it would off been crazy if you forgot to install the shocks during the frame swapIt wasn't a serious post, hence the emoji. Nobody in their right mind would drop the frame to do the shocks.
I was doing a frame swap and made sure to install the shocks before I raised the new frame into place.
I have a drill and bits. Currently I don't have a welder. I'm pretty sure a 3/16" roll pin will hold it together just fine.
It's the longest video we've put out yet but it covers the job really well and will hopefully enable you to have the confidence to do it yourself when the time comes.
Nice man, This vid is so good it gave me the confidence to do it four weeks ago. lol
Just a few things I noticed that I did a little different then you did. I never drained the front diff fluid. I jacked up one side and left the other wheel on the ground. I lost maybe 1/2 ounce of fluid total doing it that way.
Also I never popped the LBJ. I just took out the 4 bolts holding the LBJ to the steering knuckle. I'm not sure which way is better but I didn't have a BJ separator in the garage. So I went the 4 bolt route.
Thanks for taking the time to make all these. They really do give people a very good idea of what they're in for when they decide to tackle certain projects.
We heard of that method of just jacking up one side at a time to save the gear oil but I liked having the whole truck up on stands at one time. Plus, we're not talking a huge waste since it's only a little over 1 quart and it never hurts to have fresh fluid.
I bought that kit of pullers so I try to use them whenever I can but I reckon taking out the 4 ball joint bolts is a bonafide method as well.
I keep thinking of getting a kit like that but I really hope I'm done taking the front end apart for a while now. Plus Oreilly's is at the end of my street and it's hard to beat free specialty tools. lol
