Status
Not open for further replies.
Finally buttoned up the center console upgrade. New double-din head unit and USB port install. Sent the climate control unit and clock to @JRZEE2000T4RLTD and got them back and install, awesome work and very quick!
Why did you need to send out the climate unit?
Got a killer deal on the rims I wanted. Retail $130 a piece. Five of them delivered to my door for $400. Brand new. Ebay never fails to amaze me. Now to find some tires to mount on them.
Replaced the CV Axle cause the boot ripped. Now the axle seal is leaking. FML, I have to tear into all over again. All you can do is laugh I suppose.
I installed my new Hayden transmission cooler, remote transmission filter/gauge and then tried to fit 15" rotors on my 16" hub. So now those have to go back to Amazon and we will order 16" rotors again.
Finished my locker/gear installs. Filled diffs, bolted new SCS Ray10 wheels on and admired. No leaks and everything engaged as it should.
Changed the oil today. Dropped the filter onto the skidplate like an idiot. I watched helplessly as every drop of oil from the filter leaked out onto the skidplate and then the ground.
That sucks man. We've all done that or something like it.
Remove the skid plate to make driveway oil changes cleaner
Sent from my Nexus 5X using Tapatalk
I finally changed my oil this year with Mobil1 and OEM Toyota filter after I normally always pay somewhere like Meineke for them (cheap oil, cheap filter, but do it every 3k).
The goddamn filter was stuck on there so tight from whoever did the previous change that I had to run back and forth to the parts store like 3 times trying to find an oil wrench that would fit.
Never ended up finding a good fit, so I eventually yanked on it so hard I thought my wrist would snap or something, finally got that ***** off.
My point being -- simple things can end up a huge PITA -- don't feel too bad :)
Funny you should mention over tightened oil filters. I changed the oil on a friends pathfinder a few months ago, the oil filter is in a very nice spot that's easy to get to. I always install hand tight with a generous amount of oil applied to the O-ring. He bought a fram filter with the extra grip on the end. Neither of us could summon enough strength to get that ******* off. I felt bad since I had installed the filter. We ended up getting a strap wrench. Shortly after that I did my own oil change and was concerned that I may have eaten my wheaties that day and over tightened my filter as well but it unscrewed super easy. I don't understand how I can use the same technique on two filters and have 1 be essentially welded on and the other filter be just right.
This is also why I make it a point to crack loose the filter before draining the oil.
Sent from my SM-G930T using Tapatalk
Home made splash guards. After installing my Fat Pats 1.5" body lift, it was time to replace the aging and no longer sufficient stock splash guards.
The material used was kitchen drawer liner. 10 bucks CDN for 4ft. Just enough to do both sides. Happy with the final product and now we'll just have to see how tough they are.
Looks great man! Plus if you put any silverware on it they won't slide away. :D
Tire upgrade failed
Today I went to discount tire to get my 285/75R16 tires put on the stock wheel and come to find out they didn't fit due to the offset of my wheel and the tire was rubbing on the UCA's. I heard wheel spacers were bad for my truck, and I wasnt planning on new wheels right away but I guess I have to now. More money but in the end hopefully will be worth it.
Status
