Today was epic. I took the often talked about, seldom run, trail from Big Pine to Coyote Flat. There's a lot of aura surrounding this thing. Buddies have said, "Don't even try" "It's only doable on Rhinos" "It used to connect but not anymore" and my favorite "Just call me when you get stuck"
I started at about 1:00PM on the 15 mile drive to Big Pine. Filled up and got out the High Sierra SUV Trails The East Side by Roger Mitchell. He has some directions to a place he calls Glacier View. It's pretty much the Warren Bench Trail. He stops his journeys at a lookout 10.2 miles in.
That first 10 miles is all low range steep loose and rocky. Class II my ass. When I arrived at his "Glacier View" it was indeed a great view of the Palisades. I could see Sugarloaf not more than 2 miles in the distance. That was where I could pick up Coyote Flat.
Right past his turn around I saw a sign that I have never seen in the Sierra before. It said "Most Difficult. Modified 4x4 and experienced drivers only" Perfect. Past the sign was some serious terrain. Tight turns, very small clearances between obstacles and big, big. rocks. I was solo and did something I never do. I walked the first 200 yards of the trail.
It was bad. Not bad enough to stop me from committing but bad enough that I knew there could be no room for error. Luckily it was downhill and I knew gravity would be an asset here. I spotted my line and committed it to memory. All rocks on the passengers side would be blind so I would use rocks on the drivers side to keep me lined up, hopefully.
I started up the rig and dropped in. It was white knuckle time. Sliders took some hits. Tires tried to grab anything to help me. Blood pressure went up and then it was done. Or so I thought.
After a nice little 300 yards or so of not stressing I see the final obstacle. I know it's the final one because right after it there is a perfectly flat meadow. I stop and walk it. It's not long but man it's gnarly. One minute later my rigs in that meadow. On all 4 tires even.
From there it was 1.6 miles to pick up the Coyote Flat trail and home to Bishop. The loop is 30 miles of dirt from Big Pine to Bishop for those interested in doing it. As usual I forgot to take photo's of all but a few spots. If anyone wants to run this thing let me know. I'd really like some company next time. lol
