Roller bearing replacement
Scheduled my 17 SR5 Premium to have a left front roller bearing replaced. 11,000 miles. Presented a cycling drone noise from front end. This is a Toyota Service Bulletin (TSB 0026-15).
Visited Joshua Tree National Park, CA
Made a bracket, painted it, and mounted a power cut off switch for winch
installed a 20 inch light bar that fit into the upper grill area of the trd pro grill that didn't involve cutting, drilling, and that fit into existing holes. I also was able to reuse the upper grill bracket and hood latch protector, and my oem engine splash guard. Basically, it looks oem.
If anyone can tell me where I can post pics for free, I will. .... damn photobucknuts.
installed a 20 inch light bar that fit into the upper grill area of the trd pro that didn't involve cutting, drilling, and that fit into existing holes. I also was able to reuse the upper grill bracket and hood latch protector, and my oem engine splash guard. Basically, it looks oem.
Postimage.org is what i use
and the lightbar is the 21 inch lightbar that uses the short/small brackets from amazon.
https://www.amazon.com/gp/product/B00OC7KLUQ/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Only thing you need to do is buy bigger bolt and nut so you can use the oem holes in the upper grill support. The nut supplies by the light bar is too small for the OEM hole. I just rummaged through my nuts n bolt drawer and found ones that fit.
excuse my juvenile license plate, but now I have FU lights to back up my plates lol.
PS: i have no affiliation with LED light bar seller or anything like that.....i just want to share the wealth n knowledge (this is my second light bar, first one only fit if I cut stuff up).
Installed the new grill! Love how it looks
Kickass switch is all I care about. Especially when my 6yr old says......put on the party lights!
May I ask where the folks in this thread are purchasing these ACC switches that appear to be the same push button type as the OEM ones? Was just poking around searching the forum but no luck.
Thanks in advance.
