feralcomprehension
About a week ago I got a great deal on an 07 V6 4WD that had a known issue with 4Lo not working. Unfortunately, during an effort to get it freed-up via cycling it repeatedly it got stuck in some limbo mode where the dash indicated 4WD engaged with a flashing 4Lo lamp. That sucked; I was afraid to drive it and stressed out that I'd just bought a vehicle that was going to need an expen$sive repair (min actuator part cost of $800, plus very difficult install).
So a read a bunch of threads. Seems like the classic issue is that the actuator gets gummed up thru lack of use. Nothing actually fails, it just gets stuck. Given the state of my truck, I figured that was likely.
I found a post by BlackWorksInc where he posted a training document that was really useful.
I also pored over the factory wiring diagrams; these two were very useful:
Actuator/Control wiring:
ADD Control/wiring:
http://houseofun.ms11.net/Misc/Toyota/ADD wiring.JPG
Thru some of the other threads on the subject I found that user Woodless identified the actuator motors as Mabuchi Motor RS-385PH. Consultation of the online datasheets for these motors indicated that the maximum operating voltage is 30V, significantly higher than the typical in-vehicle max of 14.7V....
I know that electric motor torque rises with applied voltage. BlackWork's .pdf indicates that the expected operational voltages for these motors is 10.5-14V. There's a lot of available torque between 14 and 30V. I wondered if I could break the actuators free by supplying the motors with >14V, which I intended to supply to the actuators directly from the connectors to the 4WD computer.
Worked like a charm! Time to eat, more in a few...
ADD Control/wiring:
