05-06-2008, 05:00 PM
#4 (permalink)
Super Moderator
Originally posted by NCSCOTT
I need some picks too!!! Did you have to have an alignment??? How easy was the install, Did you do it your elf with just a set of springs compressors???? Was the seller on Ebay a vendor or an individual user that lifted his FJ???
Pics are coming... :awais: Yes to the alignment although it didn't really need it. I have friends in the business and they did the alignment. Prior to adjusting the camber it was still within acceptable, specified range. I forget the numbers. Yes on the DIY install. Easy but I did end up splitting the upper ball joint boot when I put the fork in. Yes it was a regular EBAY vendor based out of Ft Collins CO.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
