Spidertrax Wheel Spacers Installed
Ok, I had a chance to take the rig out for a spin today. City driving is fine and I knew that already as I took the spidertrax out for a quick test run after install to check for rubbing. Highway - had it on the open road for about a 15 mile run at between 55-70. I was checking for any sort of vibration or shimmy and I am quite relieved to say that there is none. I wasnt able to get the speed above 70 due to traffic conditions and I only ran them 15 miles but so far so good.
Before doing that run I did a tire rotation. Now I didnt do the rotation at the time of the spidertrax install as you are supposed to check the nut torque at the 50 mile mark and I figured that not doing the rotation would force me to check the tightness. I didnt have 50 miles on the spacers but felt that it was appropriate time to check the torque.
Why? Well, first of all the nuts on the spacers are loctited in place with the red type threadlocker. So you cannot turn the nuts when checking tightness anyhow because even if you could turn them while they are locked in place you would break the seal and then have to re-loctite them again. You would have to heat the studs with a torch to lossen the nuts or at least to clean off the old loctite. So I wasnt expecting them to be loose.
What I did was set the torque wrench to the 80lb level (3 lbs less then the level used to put them oin originally) and check them. They were fine. The wrench clicked before they turned which is what you want to occur. They should have been fine anyhow as the studs were already pre-stretched and not new.
The studs preinstalled on the spacers on the other had are brand new and I wonder if when the instructions say to check the torque after 50 miles they are referring to the factory lug nut tightness on the spacer lugs. Because being new the lug studs will upon first tightnening, stretch and continue to stretch within the first 50 miles or so. When they stretch, even if the lug nut stays in the same place, it would be loose because the stud became slightly longer.
Anyway I just reached the 5k mile mark and did the first 5 tire rotation. I will check the lug nut torque again after another 50 miles as the spidertrax lugs may stretch some more.
When tightening down the lugs it is improtant to get the correct torque so use a torque wrench. Again, I like to torque down first to 40lbs then 60 then 83. All the time using a criss cross pattern as shown by the attached pic. This will make sure everything is seated and torqued evenly.
Any more questions, let me know.
My experience with spidertrax:
I have an 05 V8 Sport with 3" spacer lift, 265/70/17 BFG TA KOs and just put on spidertrax wheel spacers.
The install was very easy. It rides as smooth as before the install in both the city and on a few hundred mile highway trip. I'm very happy with it.
Before the spidertrax I noticed the 4Runner was a bit more tippy in corners compared to stock because of the lift. The thing I noticed most about the spidertrax is that cornering feels as good as when it was stock, or even slightly more stable. That made me very happy.
Right now my only problem is new rubbing. The spacers pushed out the turning arc of the wheels and now the outside edges of the BFGs rub those "triangles" and the front mudflaps. I'll take off the flaps when I put on my shrockworks sliders (if they ever come... ordered in May). I'll either trim the front "triangles" or try moving them forward as JA did.
Doesn't adding spacers change the geometry of the suspension, like move the moment of inertia further from the fulcrum? I know with cars they don't recommend putting in wheels with a wider offset for this reason. Is it different with trucks?
looks good....I've used Spidertrax spacers for a while on my XJ (so my 31s clear the control arms using stock wheels). On the XJ it really helped with stability in cornering especially (as well as high-angle wheeling).
Make sure that after using them for a week or two, you take off the wheels and re-torque the spacer lug nuts, and make sure you used loctite red...I have heard a few stories of the spacers coming loose after a while when not torqued/loctited..
I actually have a 5th spacer for my spare, lol...
I will have to get some for my 4R eventually...
5-30-08002.jpg~original
J.A. said:
Yes, the plastic bumper does wrap into this area. I have not rubbed in the one day i've driven with the liner moved forward but if i do rub on this part of the bumper I will chop it down. The part in question is completly within the wheel well and will not be noticed. I almost want to chop it out because it looks like it would look better without it there.
Got some more miles in, 250 with the spacers on now, and well it turns out that the tire does rub on the lower bumper corner where it wraps into the wheel well area. The rubbing occurs mainly when in reverse and going up even a slight incline. The steering wheel needs to be only turned slightly to rub on this area. It will also rub when under compression. The trimming was very easy to do, not a problem at all. See pics below and more on my site.
The area that gets rubbed.
What the area looks like with only the wheel well liner moved forward. No trimming yet.
Area to be trimmed
After Trimming
Dremel tool with cutoff wheel for the initial cut, then followed up with the sanding drum then a final brief hit with some fine hand sandpaper where needed.
Love the stance with the tires bumped out just a little like that. Do you know if the Spider-Trax will work with stock sized tires at stock ride height...with or without a little trimming?
Truck looks good man. Ive been looking at some spacers. i just got my lift on and the body roll is kinda scary. you said that the spacers help with the roll. is it a noticeable change? i dont have the money for new tires now but i dont want to take my lift off either.
Thanks
Thanks
Wow, you replied to a 3 year old thread :gun4:
What lift do you have? My coilovers gave me LESS body roll. Spacers won't help at all with body roll. Having your tires out further just means you'll have slightly less resistance to rolling over.
Yeah haha. i was searching for any kind of info on wheel spacers.
I have the toytec front spacer and rear superflex coils. im looking at spacers cuz i had the lift on for about a week and i just dont feel stable on the road.
I don't think you'll be happy unless you beef up your front springs. Coilovers... stiffer springs and dampening. Spacers look cool, but won't help a wobbly ride.
I can definitely see a difference in the pictures, but are they really worth it? Exactly how much of a difference is it? Is it more noticeable in person?
1.25" difference :wink2: and yes it's worth it. 3 years and still satisfied w/ no issues at all.
