Status
Not open for further replies.
New Headlights
Just got these headlights from [MENTION=65101]BrianSD_42[/MENTION]. Stud
Wired the boost gauge and air/fuel ratio gauge.
<img src="http://i1350.photobucket.com/albums/p779/zacforsale/BDFC712B-5A80-45BA-8644-E130C1E65ABD_zpsx1y7gyfk.jpg" border="0">
Was going to wait until installed, but had to share. Redid my headliner. PO beat the snot out of the original.
Put on the OME heavy heavy lift yesterday and got it aligned today. Came within exact specs! I'll get pics in my thread soon and post some here. MIGHT be getting tires this weekend. I was just really happy I didn't have to buy UCA's to get it to align.
Got Lazy Today - Took in to Broadway Toyota
Took it into Broadway Toyota for my 320,000 mile maintenance check (JK). Actually it was time for the fluids to get replaced and I just had way too much stuff to do.
  • Oil/Filter Change - Mobil1
  • Transmission Drain and Fill
  • Replace FIPG, mine was starting to leak a bit
  • Front and Rear Diff fluids
  • Transfer Case
Drove it home
Last week I lowered my Toytec Eibach/Tundra Bilstein 5100's to the first perch from the third. Dropped less than an inch, way better ride, fixed my vibrations. Took em to a shop rather than do it myself again... The guy at the shop asked me if I had a death wish for compressing them by hand hahaha.
Today, I replaced a broken LED dash light(friggen signal light... What a pain in the a**).
Added a switch for the motorized antenna(totally copied some dude that posted his work a couple days ago here):
Then I finally installed my dash cam. Instead of routing the usb cable all the way down the A-pillar and through the dash, I figured I'd splice into my map lights and add a switch so I can turn it off. Voila:
  • Transfer Case
Drove it home
whats FIPG
Broke my front sway bar linkage.
Noticed my sway bar linkage was broken while going over speed bumps. (Makes a nice popping sound) Broke the other side a month ago while off-roading. Both broke the exact same way, clean breaks on the lower mounting point. Good news is my 4runner actually drives more smoothly. At least in my opinion. Think I'm gonna keep it this way for awhile.
Several Things were worked on today. Out of three tasks, I have two out of three done. One I can't finish yet.
These came in the mail and were waiting for me to come home. I got them installed this morning and I've very happy with them!
20150826_091513_zpsabcvbwhs.jpg~original
Other parts came in the mail...
I got my coolant temp gauge and other parts as well. Now don't judge the mounting plate. Right now I'm wanting to make sure everything works and lasts.
20150826_142135_zpsaxd8efox.jpg~original
20150826_142038_zpsfdmnkpa4.jpg~original
The one part that doesn't work (and makes me quite mad) was the Coolant Hose Adaptor:
Amazon.com: Docooler® Water Temp Temperature Joint Pipe Sensor Gauge Radiator Hose Adapter 32mm Blue: Automotive
I called TWO DIFFERENT parts stores to verify the diameter of the of the Radiator hose and they both said 1 1/4". No, it's 1 3/8"!!!! So I have to get a larger one. Right now I have the sensor zip tied near where it needs to go to test out the gauge. If everything works, I'll make a new mounting plate for it all. Clean it up and make everything flow real nice.
So the one on the left is the cab temp. The middle will be coolant temp, and the one on the right is engine compartment temp. I don't like how the Koso Gauge is only attached with Velcro. I really need to find a way to get it recessed like the other two gauges.
Where did you get those swaybar links?
Status
