5spd swap, HERE GOES NUTHIN!
Jon
I think I have enough parts to start the swap thread now. I went and picked up the donor 98 5spd, t-case, front drive shaft, flywheel, master cyl, clutch pedal, new in box ECU, cross member and center console. Guy also threw in a starter and a few coil packs. Got all that for $400 and spent about $100 in gas. The wife's 04 Forester 2.5XT was gettin it, cruise maxed out at 90 and managed 18MPG. Still need STi turbo, intercooler, intake, exhaust and a COBB tune but that's for another forum.
Still need to get a clutch, slave cyl and build a clutch line. My auto is almost ready to pull just got the 6 bell housing bolts, cooler lines and the cross member. Wish I had a trans jack for this! It's gonna be fun:hungry: I'll get pics up later today.
You might as well drop in a crawl box at the same time. Do the driveshafts once. I love my 5 speed, just wish I could crawl more.
One thing that might be an issue, is whether the crankshaft of your 5VZ-FE is machined to accept a pilot bearing for the input shaft of the trans.
Just please keep this thread updated, your information and tips will provide other people invaluable information for many years! Keep pics and information coming our way!
Jan 3rd Progress update- All that's left is 2 cooler lines, 6 bell housing bolts and drop the cross member. Taking my sweet time. The torque converter bolts were the worst part so far. Just hard to get at. So far so good. I know it's dirty! Shes been collecting dust for 4 months and burped up a few qts of trans fluid after I purposely overfilled it. Can't wait to get some fresh mud on her!
Got a little bit done tonight, all the hard stuff is done. Cooler lines removed, trans is held to the motor with the two lowest bolts only and the cross member just has the outer bolts keeping it in. Ready to drop it tomorrow. Probably gonna lower it with my big floor jack with the assistance of a few ratchet straps hung between the frame. It's worked in the past.
If Toyota had put half the effort in designing the radiator as they did routing and securing the cooler lines then I wouldn't have this problem! Lines are bomb proof!
Still in no rush really. Have yet to order any parts. I am going with the F1 Racing clutch kit over Marlin Crawler. Marlin is out of stock on flywheels (F1 kit comes with one) and they can't put together a comp clutch for the 3.4 only their stage 1 HD 1200lb. I really like a 6 puck clutch and have had good results in the past from Ebay clutches in street/strip cars. I'll be getting with Marlin for the other little stuff like HD flywheel bolts, clutch fork boot and slave cyl. Gonna try to use off the shelf line from Advance Auto for the clutch line.
Should I replace some seals before I install the trans? It should have a front main seal or something around the input shaft right? Thant's all for now hope to have more tomorrow.
I hope so! Would they really have different cranks for auto's and manuals? That would suck!
Got the trans down last night. Went pretty smooth with my makeshift trans jack (plywood bolted to my jack) and only one set of hands.
Two plugs that I didn't see until the trans dropped a bit, no harm done.
Just removed the jack pad and bolted a piece of 1/2 ply to it, worked out perfect
Obviously the valve cover gaskets need to be replaced, but I didn't know it had gotten that bad! Looks like the crank is good and has the place for the pilot bearing. Gonna do the rear main while it's out too.
jon you are one BAMF!!! i might do this when my tranny goes
Yeah buddy, you know it!:cheers:Beast! JK, when your short on cash and/or don't trust people with maintaining your vehicles, house.... you'll end up doing it yourself. Practice makes perfect. Not that I'm perfect at all, but practice, got plenty of that. I remember smoking my first trans when I was 16 in my 96 Dodge 1500. Dad says "You know where the tools are and you got a Hanes Manual, have fun."
Swap is postponed till I get the $ from the deployment.
no they will be the same, dont worry, i could not see toyota doing this, infact i do not now of a auto manufacture that does this.
my only concern is with the clutch you have chosen. it sounds to me like a competition clutch no? if so then you will hate it on the road and trails. they tend to be either in or out and no slippage is allowed -sometimes you want to slip the clutch especially off road. also im willing to bet the peddle feel with be much stiffer and you left knee will want to slap you after a day of driving it. if i was you id look into a centerforce dual force clutch. they are amazing, i have them in both of my toyota pick ups and man they feel like a stock clutch but have over twice the holding power, -i think they are rated at like 340hp(for a 22re clutch) and there is no way a NA 22r is gonna make that kinda power. plus you can slip them all day long(im running 33s on stock 4.10s and have never smoked that clutch once. and ive worked it hard, doing everthing from wheeling to hauling 2.5yrds of 3/4- in city/town traffic. the centerforce clutch is hard to beat.
I've seen various engines originally equipped with an auto trans over the years, with cranks that have not been machined for a pilot bearing. That's in applications where a manual trans and an auto trans were available from the manufacturer.
I only mentioned it as a possibility. He already stated that his crankshaft was machined for a pilot bearing, so he should be good to go.
I was curious about whether this was an issue for the 5VZ-FE, so I Googled and found a shop that had run into the issue.
A link: TOYOYA INFORMATION AND LINKS
Quote just a little ways down in that link:
If you are using a manual transmission, the 3.4L engine will need to come from a manual transmission vehicle. In SELECT year models we have found a difference in crankshaft machining from the factory. In these instances an engine from an automatic transmission application will not accept a pilot bearing. Another reason to purchase a manual transmission "package" is the difference in electronics. The engine ECU and the engine wiring harness are completely different from manual to auto. Based off experience, we recommend purchasing all the used parts from one manual transmission vehicle. Once again, purchasing all used parts from the same donor vehicle has been proven to prevent grouchy mood swings.
Jon, which site are you referring to in terms of the Fozzy? SubaruForester.org or Nasioc?
I'm on both but not to much activity for a while. That project is near the end of the list.
Thanks man, that's what I needed to hear. I haven't got any new parts yet. So is this the one you're talkin about? Centerforce DF505019 - Centerforce Dual Friction Clutches - Overview - SummitRacing.com At that price I really hope you get what you pay for, I still need a flywheel! I tried my buddy Jordan's Marlin Crawler HD clutch (98 Taco 2.7) and it has a factory feel to it. Real light. I might just wait till they get all the parts in that I need and get it all from them. I can never make up my mind!:ybrick:
thats the one. ive had nothing but happy happy times with centerforce clutches. if i had a 5spd thats what id be using even if it was SCd. i think they are better than the TRD clutch ect. sure there are clutches that have way more holding power but there is no middle ground with those. it either engaged or disengaged, and they are stiff and not fun to drive on the street. unless i had a vehicle that was not able to be driven on the street and race only it would have a CF DF clutch. until you drive/use a vehicle with one for a while and know what i mean its hard to explain. basically its like having the best of both worlds.
The last 5spd that I owned was my built 5.0 325whp and a stage 3 clutch that would wear you out pretty quick. It'd take all 110 lbs my wife had to push that pedal, she almost stood up in the seat. But it also feathered just fine. But I've been spoiled the last year or so offroading with the auto. I imagine there's going to be a lot of clutch work so the softer the pedal the better.
