Scangauge question: AT Temp?
Martinjmpr
I've seen conflicting reports on whether the Scangauge II can be made to show AT temp. Some say yes, some say "maybe." Anyone know for sure?
I'm currently running an Ultragauge but it does not show AT temp on the 3rd gens and according to the Ultragauge website, there are no plans to upgrade it to do so.
I've recently been thinking of adding an AT temp gauge to my '99 SR5 but a scangauge would probably be less expensive and I can always throw the Ultragauge into my DD 97 Mazda which has a manual tranny anyway.
A smudge more research and you would find your answer.
The SGII will show ATF temperature on 99-newer 4Runners. It will NOT show an ATF temp for 96-98's.
The 96-98's do not have the same physical trans temp sender as the newer ones. Hence, the OBDII does not read a specific temperature during operation, it simply sets the "idiot" light off when the trans gets over temp. Which is probably north of 300 degrees.
What he said.
My sgII reads my '99 tranny temp just fine.
This, my buddies SGII showed my 2000's sr5's AT temps after my bm70268 cooler.
here's some of the custom codes we've come up with for the Scangauge II...
Transmission Temperature #1
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
Notes: n/a, displays in degrees F
Air : Fuel Ratio #2
TXD: 686AF10124
RXF: 04410524
RXD: 2808
MTH: 05B900800000
Notes: Ratio
1150 is Rich/ 1775 is LEAN
**My Runner stays around 1453 to 1465 most of the time now with this code
Altitude Gauge (Feet) #4
TXD: 686AF10124
RXF: 044105240000
RXD: 2808
MTH: FEEE00016B08
NAM: Alt
This one doesn't work correctly yet
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
Im pretty sure thats the same code we used on my buddies SGII for the Trans Temp in my 4runner.
He also has some codes for engine HP and Tq. It says his 3.5L Isuzu Trooper makes like 230hp
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
Air : Fuel Ratio #2
TXD: 686AF10124
RXF: 04410524
RXD: 2808
MTH: 05B900800000
Notes: Ratio
TXD: 686AF10124
RXF: 044105240000
RXD: 2808
MTH: FEEE00016B08
NAM: Alt
Sorry, another noob question. What do these numbers mean and how would you input them into the gauge?
[MENTION=121089]Fit4Action[/MENTION]
I just told you in the previous post where the instructions are for entering the data in. I also included a PDF version of the manual. It's self-explanatory.
It's nothing more than hexadecimal, binary, code. Just found a pdf extract of the different byte parameters used. Enjoy
