high beams
iliquer
i recently converted to HID projectors using to factory LH bulb plug wires which allows lights to power on as normal. The high beam indicator light doesnt come on anymore. Is there a way to "Jump" the RH plug to tell the dash the high beams are on?
Need to know if you had DRL's as stock, and how they were defeated for HID if you did. DRL and non-DRL wiring is totally different--one is switched hots and the other is switched grounds. The last one I looked at, I figured out that it is not really a hi-beam-on indicator, it is a headlight-on-but-lo-beam-off indicator, but I forget if that was with or without DRL's.
