Suprareal's Build Thread
Suprareal
Suprareal's Build Thread ( Pic Heavy )
This will be my build thread, adding little by little as i can. Wait i think im done... 4wd conversion might be in future plans though.
1998 2wd Auto 3RZ 4 cylinder ( City DD ) 3.90 stock gearing.
CURRENT AS OF MARCH 2013
IMG_5117_zpse131f530.jpg~original
This is what i came from... 89 Buick Electra V6 FWD and i loved it believe it or not. Wish i still had it. Ran like a champ just looked like it did not.
DSC00270.jpg~original
Here she is when i first layed eyes on the craigslist add in October 2010
Bought it at $3500. 184,000 miles including Full suspension setup in almost new condition and brand new tires.
fd3cfad17d9b5a5eb1d8_2.jpg~original
IMG_0833.jpg~original
IMG_1011.jpg~original
IMG_1010.jpg~original
When i got home i could not stay away from the thing
img051.jpg~original
When i bought the truck i never intended to mod it further than window tint but this site broke my bank and changed my mind.
First thing i did was install my sound system and tinted windows
35% windshield/fronts and 5% limo the rest.
IMG175-Copy2.jpg~original
I've always loved black rims so knew i would do that from the beggining.
IMG175-Copy4.jpg~original
I then discovered the oil pan gasket was leaking so i replaced all the Gaskets, seals, o-rings, filters you name it, in that area and never had a drip since.
Out of all the parking this guy decided to make me look like a Hot wheel at work, i said awh man what a $#%^, then he came in and i had to make his pizza...
IMG_0627.jpg~original
Then i discovered clear corners and blinkers and bought a set on ebay
And fixed the broken antenna by replacing the plastic rod and actual antenna
Before
IMG_0750.jpg~original
Clear
IMG_0814.jpg~original
Then to translucent black blinkers
IMG_0817.jpg~original
The first disaster i encountered happened the first time it rained... i guess i was missing a roof bar bolt and it let water in and filled up the sides of the headliner and somehow dripped and filled a pair of shoes and soaked the rear carpet. i ended up vacuming a equivilent of about 3 water bottles of water out. Still amazed to this day how bad it was.
Here i am airing it out ( smelled horrible for weeks)
You can tell how mad my dog was that this happened to me "AWHH"
IMG_0684.jpg~original
cool color. I didn't get where Supra comes from though.
I was looking forward to some twin turbo goodness.
I wish! haha
The names something I made of from skateboarding a while back, used it on eBay and other sites so I went ahead and used it here.
I then started liking the look of smoked tails so i did them and plasti-dipped my emblems adding a trd emblem. if your paying attention yes this did come before the tint, i forgot :spider:
IMG166.jpg~original
IMG_0838.jpg~original
IMG_0840.jpg~original
Replaced the front sway bar bushings with Polyurethane
Changed oil and whatnot around this time also
IMG_0841.jpg~original
All of a sudden my paint started oxidizing on the top of the door. Had to fix that quick before it got worse.
I ordered a touch up paint pen from the stealer reduced it with lacuer thinner and shot it through a airbrush, then applied auto clear coat from a can. matched perfect and holds up.
IMG_0796.jpg~original
After
photo312.jpg~original
I changed the cluster lights and corners to pure white LED's
photo44.jpg~original
Wade In-channel window visors front only
IMG_1092-1.jpg~original
I knew i needed more HP :lmao: so i painted my calipers red and added the high temp TRD decal which hold up extremely well.
IMG200.jpg~original
I wanted my truck sound deeper than stock but not loud, after alot of research i finally went with the MagnaFlow 18'' welded up to stock pipes. Amazingly it was the exact sound i was looking for and i have never had any problems with it.
IMG_0846.jpg~original
Surf185 came to the rescue with a front bumper 100% better than mine and a grille ready for the satoshi mod.
At the same time i added aftermarket glass 99 and up headlights from ebay ( great quality) and some hella 500 flood fogs i got for christmas.
IMG_0903.jpg~original
After scanning craigslist for forever i found a set of BFG all terrain 265/75/16's for 50$ right around the corner with Very decent tread. I needed to find 16's for them so i ended up trading my dad for his off his tundra for some other rims and tires i bought for him on craigslist. (chrome sequioa 3 split ) and i painted the black of course.
IMG_0939.jpg~original
photo29.jpg~original
I was trying to figure out the noise (errrt) that is made from shifting from reverse to drive so i replaced both U-joint's, did not solve the problem but feels smoother after replacing
I went with the best ones from orielly auto parts with zerk fittings of course
HPE_285.jpg~original
I replaced my brake pads before i started modding but i finally got around to matching my shoes, i have wagner thermo quiet on all four's
826729460_260.jpg~original
My dash was coming apart and got worse over time, i was sick of looking at it and ended up buying a whole other dash from Crossroads auto dismantelers AKA where 4runners go to die.
IMG_0980.jpg~original
IMG_0978.jpg~original
Damn they look sick! That's what I plan on doing next. I dont see any hot spots either. where did you order the bulbs? v-leds?
Around the same time i added the tires i added the K&N CAI
sounds great and unlike some i did feel a big difference
knnn.jpg~original
I wanted a keyless entry with a small remote so i went with the viper 211hv
IMG_1125-1.jpg~original
All of my sway bar end links were in need of bushings so i just replaced them all with Moog heavy duty ones (65$ each retail) but got all 4 for 45$!
photo113.jpg~original
T4R.ORG sticker !
DSC00386.jpg~original
Cat theft=new cat and a custom diamond plate cat "skid plate"
IMG_1017.jpg~original
IMG_1033.jpg~original
photo54.jpg~original
And my guard dog of course =] keepin a eye on it now
IMG_1126.jpg~original
Finally i was able to paint my hood after the cat replacement, set up a spray booth and got it done. ( paint does match even though here it looks like it does not)
And added Hella cages and new TRD plate frames.
IMG_1055.jpg~original
yum.jpg~original
I ran a switch to the remote wires of my amp (bottom right) so i can easily turn off my bass when i need/want to. One defroster switch is for my hella fogs and the others are currently waiting to be used.
photo214.jpg~original
