Monroe quick struts + moog rear coils after pics
ocman40
I didn't take a before pic but here is an after. I replaced the struts, shocks, brakes, rear coils, bushings etc. Another member here wanted to see a pic. I know these components claim stock ride height but my truck sits much higher. Prob 1.5 inch or more.
Best part is the quick struts are a breeze to install and i paid about 85 a piece after discount. 36 bucks for moog springs after discount and 30 bucks a piece for monroe sensa trac shocks after discount. 266 total. Oh and 55 for an alignment.
the quick struts are the only way to go...lifetime warranty, never again will you have to buy a spring or shock for that truck
if you took the running boards off that thing it would look like a lifted T4R and make you not look 90...lol
She looks great. I put the Quickstruts on awhile back and it gave me a bit of nosebleed stance like an old 60's gasser. I need to install some new rear coils to even things out. What Moog number did you use? Thanks.
81043. Advance auto has them for 56.99. There are a few codes you can use giving you 20 bucks off 50 making them 36.99
i just installed quick struts and now the front sits noticeably higher than the rear.. any chance these things will settle after awhile?
the last owner installed rears so theyre fairly new. It might level it out a little, but then it would look like I have a 3 inch lift all around.... The rears are not sagging at all, I'm sure of it..the fronts are way too high...I thought new fronts would only level it out but it really added heighth. I'll take a pic and upload it later... Wonder if I take a torch and heat them up they'd settle..
