04-10-2012, 04:00 PM
199mm Tundra Brake parts
I'm looking to do the upgrade to the 199mm Tundra brakes. I know why not do the 231's...I just don't want to run into problems with wheel fitment or something down the line.
Anyhow, anyone know the part numbers for the oem pads? Remember, I'm using the 199mm not the 231's.
Also, anyone know if there is some other parts need besides the pads (shims, etc...)
Thanks for the help.
2001 black 4runner sport
Replaced at 180,000 Miles: Tundra 199mm brake upgrade with Advanced Auto Platinum pads and Brembo rotors and stainless steel extended lines. OME 906s with 10mm trim packer and Bilstein 5100 (Ford F150) in the rear, TRD Tundra springs with Tundra Bilstein 5100s up front. New Toyota lower ball joints, Autozone inner and outer Tie rod ends, and all polyurethane on front and rear sway bars
04-10-2012, 04:14 PM
Go here:
Toyota Parts - Genuine OEM Toyota Auto Parts and Accessories
Search for a 2001 Tundra.
Then select Power Train/Chassis, then 47-05 Front Disc Brake Caliper & Dust Cover. Should be the first item listed, PAD KIT, DISC BRAKE, FRONT.
If you want another option, though, these are what I used for my 199s:
Calipers: Advance Auto Parts, Buy Fenco Disc Brake Caliper, Front Left SLC9689 at Advance Auto Parts (left) and Buy Fenco Disc Brake Caliper, Front Right SLC9688 at Advance Auto Parts (right)
Rotors: Amazon.com, Brembo 25534 (x2)
Pads: Amazon.com, Akebono ACT812 (1 set)
I just sourced parts that would fit a 2001 Tundra.
Total cost ~$300 (not including the $100 core charge you pay up front for the calipers but that you get back when you return the old ones)
2000 4Runner SR5 2wd | 3.4L V6 Auto | Millenium Silver Metallic | 218,000 miles, 1 owner | Sonoran Steel 3.0 ('99 coils) | Tundra 199mm brake upgrade - Brembo blanks & Akebono pads | Koyo 1998 radiator | Bridgestone Dueler A/T 265/75/16 tires | Hella MicroDE fogs | Rear-facing aux lights | Deckplate mod | Fiamm Freeway Blaster horns | Curt Class III receiver | SilverStar Ultra bulbs
04-10-2012, 04:16 PM
side question, i was wondering about this as well, since toyota stopped using the 199mm set up and it was basically a 1-2 year production run, what do you guys think the parts availability will be like for 199mm pads and rotors and such in say 5-6 years?
i was wondering if these parts will be continued to be made and supplied indefinitely........
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
04-10-2012, 04:21 PM
Just a guess, but I would imagine that availability will outlast most of our trucks. We're already 10-15 years old. Another 5-6 years and we're pushing 20. If you're worried, then stock up now!
04-10-2012, 04:45 PM
199mm tundra brake
I've looked up the Tundra on partzone and it lists 3 pads. One has been replaced by another so actually there are only 2 but it scares me that 2 are showing up. I want to make sure it's the one for the 199mm calipers.
There is also a shim kit and fit kit shown but I don't know if these are needed. Anyone else buy OEM pads for their Tundra brake upgrades?
04-10-2012, 09:56 PM
Real Name: Mason
Real Name: Mason
So I will be doing the 199mm or 231 in just a little bit here.
This is what I sourced from Autozone for the 199mm...
Duralast Reman/Brake Caliper - Front
Part Number: C9688
$74.99
+Core: $30.00
Part Number: C9689
$74.99
+Core: $30.00
Duralast/Brake Rotor - Front
Part Number: 31267
$54.99
Duralast Gold Cmax/Brake Pads - Front
Part Number: DGC812
$64.99
Are these all the parts I would need? Leaning more towards the 199mm as I'm a little worried to grind down my rims and Calipers to fit the 231 even though I think they are better priced. Just seems you should not grind down those parts.
Please chime in if these Autozone parts are not the way to go.
Mason
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
04-10-2012, 10:33 PM
2 calipers, 2 rotors, and a set of pads. That's about it. Brands are up to you. The pads should come with shims, and if you prefer to use the clips from your old calipers instead of the ones that come with your new ones, you can. Get a bottle of brake fluid, too, to replace what you lose when you bleed.
04-11-2012, 07:50 AM
Price it out at www.rockauto.com and save a bunch of money. Google the coupon code and save an extra 5%.
The 199mm calipers are part number S13WE and the pads will have the 4.7" backing plate. The Wagner ThermoQuets have been great for mine so far.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
04-11-2012, 06:01 PM
rock auto not all that great of a deal
I did price it out a rock auto and it's not that great of a deal as you need to pay to send the cores back so don't forget about the cost of shipping. Plus they don't have the Brembo rotors and you can get them for under $50 each on amazon. Advanced has a 25% off brakes deal going on now and they have the Akebono pads for $50. I'm a little leary using the Fenco calipers but with the discount it's the same as rockauto. I wish autozone had a discount like this as I like their calipers.
04-11-2012, 08:14 PM
The calipers I got from Advance (linked above) work great, but they have developed some surface rust, giving them a burnt orange color. I've heard this is common with remans, but not sure which brands are better than others about it. A preventative would be to paint them before putting them on, which I should have done. That is seriously my only complaint about the whole process, though.
04-11-2012, 10:21 PM
Real Name: Mason
Real Name: Mason
Just bought these calipers...
Part Number: C9688
$74.99
+Core: $30.00
Part Number: C9689
$74.99
+Core: $30.00
Still researching which pads I should go with. Was thinking OEM but don't want to get raped at the service counter. Wish I would have ordered them along with my LBJ's as they are only $55 online. Still not sure which brand rotor either but they all seem like they are made in China so I guess no difference unless I go $90+ on them
04-12-2012, 12:43 AM
I have the Autozone rotors with the 199 calipers and I keep warping the rotors. I'm not sure if it's the cheapo rotors or not but I don't use the 4Runner for towing and I drive pretty mellow. I think I'm going to get the rotors turned and use some factory pads.
1999 4Runner 4x4 Limited-diff lock, Bilstein 6112's, OME 890's, Savage skids, Tundra brakes, Scan gauge, B&M 70264
2012 Dodge 3500 CCLB Laramie 4x4 Max Tow
04-12-2012, 12:52 AM
With the Brembo rotors and Akebono pads mentioned above I have had no problems at all in over a year. You may be overthinking it a little, which I totally get because you want to get it right. Akebono was/is the OEM supplier for several makes/models. Not sure specifically whether the Tundra was one, but they were for my wife's Nissan.
04-12-2012, 04:23 PM
Real Name: Mason
Real Name: Mason
Going to buy the Tundra 199mm Pads at the dealer for $80 (would do internet but want to do the job this weekend). Will they come with shims or will I have to buy them separately?
06-01-2014, 04:13 AM
Real Name: Morgan
Real Name: Morgan
difference between 199 and 231
First I am sorry to revive this older thread!
So... I guess my biggest question and concern is regarding the difference between the 199mm and 231mm brakes?!
Is the difference in the rotor? The caliper? The pads?
The only rotors I can find are 318mm in diameter. And I have not found any difference in calipers.
Please can someone help clear this up for me?! THANK YOU!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
