Old 06-07-2012, 03:13 PM #1
USMC_Spike USMC_Spike is offline
USMC_Spike is on a distinguished road
Basic Anjusting Rear Brake Thread
Question:
Can I adjust my rear brakes as I did with GM
by driving backwards then forward, then back?
If I can't do that then what is a simple way to adjust the rear
brakes.
I'm getting soft pedal feel and with pressure sometimes they will
lock up so I think it is adjustment time.
Cheers,
Spike
USMC_Spike is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 03:23 PM #2
IanB's Avatar
IanB IanB is offline
IanB will become famous soon enough
MY GARAGE
IanB's Avatar
MY GARAGE
I believe using the ebrake tensions the rear brakes on these trucks. I'm not 100% on that however.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons springs/shocks, XD HID lows
'15 4Runner Ltd - 1" front spacer, FJ Cruiser 8 holes w/ 255/75/17 Duratracs, XD HID low/9011 high beams, Sprint Booster, Husky liners, Canvasback cargo liner
'91 Toyota LandCruiser VX Ltd 4.2TD RIP - 3X e-lockers, winch, OME 861/862, 285/75/16E Duratracs, factory fridge
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 03:57 PM #3
tek9 tek9 is offline
tek9 is on a distinguished road
I found this guide that covers the brakes pretty well:
How to change brake shoes / drum brakes | Mike's Tech Blog
Hope it helps.
tek9 is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 04:03 PM #4
Shibby! Shibby! is offline
Shibby! is on a distinguished road
Either hitting the brakes firmly in reverse, or rolling backwards (on a slight hill climb) and repeated tensioning of the e-brake will do it.
Few words of WARNING:
Our brake systems are known to have issues adjusting. Especially aftermarket pads/parts.
Keep an eye on temperature after the above method. Ideally, you should raise the rear of the vehicle with stands/stops and adjust by hand and noise. Pull the rubber plugs and use a flat blade screwdriver to turn adjuster a couple clicks at a time till you hear light rubbing. The adjuster only turns one way unless you move the release with a second screw driver. Do both wheels. Once again, keep an eye on temperature. Shift to neutral or pull clutch and make sure vehicle moves freely when it should.
Shibby! is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 04:08 PM #5
Richard808 Richard808 is offline
Richard808 is on a distinguished road
i believe you can pull the e brake a bunch of times to adjust it. Just hold the button and engage and disengage it a bunch of times. I had to pull mine probably 50 times after doing new brake shoes. mines a 96. not sure if it is different on later years.
Richard808 is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 04:29 PM #6
mmml4's Avatar
mmml4 mmml4 is offline
mmml4 is on a distinguished road
mmml4's Avatar
Use your parking brake on a regular basis and they will stay adjusted.
99 4runner SR5 3.4 auto, in the rebuild/build process
2wd to 4wd, SAS, 80 series LC axles and transmission
My Build, http://www.toyota-4runner.org/3rd-ge...ild-build.html____________________________________________
"The significant problems we face cannot be solved by the level of thinking that created them" Albert Einstein
mmml4 is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 10:08 PM #7
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk has a spectacular aura about TheDurk has a spectacular aura about
MY GARAGE
TheDurk's Avatar
MY GARAGE
Sounds to me like you need to pull the drums and do a clean and lube and then adjust. You will also be able to be sure you don't have leaking axle seals which could allow oil to get onto the shoes, easily causing your symptoms. (Oil causes crappy braking, but it can also swell shoes and make them lock up.)
Just doesn't sound like a simple adjustment issue to me. Have you any idea when they were last serviced, or at least inspected?
My Backyard Frame Swap
Old 06-07-2012, 10:35 PM #8
Stallion Motors Stallion Motors is offline
Stallion Motors is on a distinguished road
I came here to post this exact comment.
+1
Tom
Stallion Motors is offline   Reply With QuoteReply With Quote
Old 06-07-2012, 11:24 PM #9
I read the part of lock-up and breezed over it slightly confused. This is correct.
Pop the drums off. Probably bad news coming. =(
basic brake job questions tcpoob General Discussions 3 03-28-2011 08:53 PM
Another 231mm brake thread jacob7071 3rd gen T4Rs 1 03-01-2011 11:20 PM
Basic Brake question - Wagner Thermoquiet Ceramic SkidPalace 3rd gen T4Rs 6 10-13-2009 07:41 PM
Rear Brake rotor replacement DYI Thread? SoCalMike 4th Gen T4Rs 0 01-30-2009 11:11 AM
Just a basic rear locker question Falls Off-Roading 11 01-05-2009 02:07 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
