How To: Wiper Fluid Resivoir Reloction
PNWRunner
How To: Wiper Fluid Reservoir Reloction
With plans to upgrade to 315's in the near future, I figured I would go ahead and tackle the wiper fluid reservoir problem that many who choose to run 315's will have to deal with. The stock resivoir holds something like 2 gallons and takes up a good portion of the passenger wheel well. Even with a 1" BL my 285's come close to contacting it at full stuff. Not to mention that since my ODL front bumper, the thing hung down about 2-3" past the lowest point on my bumper. Ugly.
coolant1.jpg~original
I saw a writeup on EP where someone used PCV routed by the radiator. He had a 3rz and no A/C, but on my 5vz with A/C there was no room for that setup.
I stoped by shucks/kragen/oreillys (im sure vato-zone and others will have it too) and got this: IDQ - Auto A/C Products & Sealing Solutions
Its a small 1.5 qt coolant overflow that fits perfectly between the core support and the stock airbox. It cost me $10 and came with mounting hardware and everything. I couldnt have made anything better myself.
I removed the front and rear motors and the rubber grommets that sealed them. I then drilled 2 holes in the bottom of my the coolant overflow, just big enough to squeeze the grommets in. I made my holes a little smaller than the ones on the OEM tank, just to ensure theres no leaks. I ended up with something like this. The OEM grommets make really good seals, theres not a drop of liquid coming out even when I added pressure to it.
coolant2.jpg~original
I pulled the wiring from down in the fender and had it come out by the airbox, then dropped the tank in there, bent my bracket and bolted it down.
coolant3.jpg~original
coolant4.jpg~original
Theres no room for it to wiggle and the bracket holds it up so the motors arent resting on anything. It also still allows you to get to the lightbulb. Im happy with the way things turned out, It's alot better than scrapping the wiper fluid, which was going to be a PITA during winter. And look at all this new space!
coolant5.jpg~original
I hope this helps someone, let me know if you have any questions.
Never have I had this problem before but the last wheeling trip I did made me lose all my washer fluid from the reservoir due to the tire that kept on knocking out the plug.
This was something I needn't be concerned with in the past until now.
It's time to address the issue once and for all.
You are a genius man! thanks!!:trophy:now only if I could find something like that here in Vancouver.
Capacity is 1.5 qts. I cant recall a time where Ive used that much fluid on a single trip, so its going to be plenty for me. I havent even used that much in the year+ Ive owned the vehicle.
Yeah, that's not too bad; i burn through the stuff pretty quickly driving up the mountain highways in the winter. I guess it probably only adds up to 2 gallons per winter, at most, so I'm gonna have to look into it. I'm installing my painted odl bumper today!
Thanks for the write up. I recently did tho mod and love it. My stock had a leak so I decided to upgrade :)
Hello PNW, many thanks for posting this modification. I believe I need to follow your lead on this one... May I ask, where did you relocate the fluid pump motors?
Thanks in advance!
Thanks in advance!
OP hasn't been online since 2014, and this thread hasn't seen any action since 2013.
Try this: Alternate Search for T4R - 3rd Gen Section It's very possible somebody has already addressed your question. If not, then consider posting a new thread.
Best of luck!
Thanks cl4RK, greatly appreciate that. As soon as I replied, I looked at those same aged stats, doh!
Never the less, while I have you, perhaps you may know. And idea where one might find the EV part number for the OEM wheel well plastics? I am looking for the black molding that protects the OEM wiper fluid tank from the wheel. I havent had any luck in the EV sites.
Hail mary here, I realize. Thanks none the less!
No worries, has happened to me plenty of times!
I don’t happen to know the part numbers; I’d be digging around parts sites and diagrams as well.
But I’ll watch this thread as there are a few parts in that area of the wheel well that I’m interested in as well…
Best of luck
Thanks again, I was able to find the OEM PN finally. I ordered the replacement for part. Here is the diagram of that area. Located in the "Electronics" header within the Windshield Wiper items. Go figure.
