Fishwerks' Photo/Build Thread
Took some pictures after fishing the other day.
P1030258 by FR4R, on Flickr
P1030262 by FR4R, on Flickr
P1030263 by FR4R, on Flickr
P1030265 by FR4R, on Flickr
Also started getting the rear suspension dialed in, starting with extended travel Bilstein 5100s from Toytec. Those went in without a problem, but I really don't like changing the rear shocks on these trucks.
Extended 5100s by FR4R, on Flickr
Also bought some bumpstops from a Chevy Blazer, aka "junkyard bumpstops", cost me $20 from the local yard where they pull parts for you (see http://www.toyota-4runner.org/3rd-gen-t4rs/134139-junkyard-rear-bump-stops.html and http://www.toyota-4runner.org/3rd-gen-t4rs/139991-bumpstops-buy.html) I only have the passenger side installed right now, I sheared the bolt off in the mount for the driver side :dammit:. I'll be drilling that out this afternoon. And I have an extended rear brake line I need to install. I need to check if I can get away without installing the brake line for now, I want to go wheeling tomorrow.
Good to hear the Bilstein's went in without too much of a fight. Your 4runner is looking good! Did you trim down the Blazer's bump stops at all like in the junkyard bump stop thread? I might go that route when I do my rear lift as it seems the easiest/cheapest.
Any luck with the sheared bolt? [MENTION=82275]4ever4running[/MENTION] and I did the exact same thing and I haven't gotten around to getting mine out yet.
My Shorthair loves a good fish lick too!
Thanks Kraze! I did not trim them down yet, the shocks sit at about 19" at ride height, and compressed length is 14.9" and the bumpstop is about 4" from the axle right now. It seems to be appropriate length so the shock won't over compress. And the bumps are pretty soft so they shouldn't limit up-travel too much. I haven't been able to wheel it yet and check everything out though.
No luck, my drill had no chance. I took it to the Addicted Offroad shop here in Fort Collins and Scotty said he will just plasma the bottom piece of the mount out and weld in some new plate with a nut on top, just like the factory mount. It's getting done Wednesday. I trust Scotty more than some $8/hr tech with a big drill. I think drilling it is possible but damn that bolt is hard and its just in a tough spot. Plus I messed up the hole a bit trying to drill it out myself...
That makes 2 of us...I've just been too lazy because I don't want to deal with it.
Yeah I wasn't happy at all. I thought :party: $20 and 10 minutes for longer bumps. Wrong. Hahah. Oh well I guess. Let me know how drilling yours goes.
:fishing: He was really concerned when I let the fish swim off!
Went on a little shakedown run now that the extended bumpstops are both in. I also removed the front sway bar and moved the front links to the rear. Everything works well for the most part, but my driveshaft REALLY gets into the stock gas tank skid now, I'm trying to decide which gas tank skid I want, probably the Lil Skips.
DSC01669 by FR4R, on Flickr
DSC01670 by FR4R, on Flickr
DSC01671 by FR4R, on Flickr
DSC01673 by FR4R, on Flickr
DSC01678 by FR4R, on Flickr
And picked up a spare 80-series wheel for $20. It's ugly because it was a spare, but it isn't pitted at all, so a bead blast and powdercoat will have it looking better than new.
Untitled by FR4R, on Flickr
That's some awesome scenery you have up there. And nice find on the LC wheel! Looks like we both ran into the same problem with the gas tank skid with our similar lifts. Hopefully aftermarket skids will alleviate our problems! Although my driveshaft is awfully close to the gas tank itself, even on flat ground with no skid on so I might be screwed haha.
The scenery in Colorado is pretty much unbeatable! I read about your driveshaft/gas tank skid interference problems, it's crazy that it hits just on the road. Hopefully a skid will solve your problems man. Going with an Any7?
Yep, already ordered it from them actually. They said it should ship out sometime next week! I was thinking about getting an adjustable panhard bar to maybe pull the axle away from the drivers side, but I'm not sure if that's a good idea just yet. We'll have to see if the new skid will give me enough clearance by itself.
Hopefully yours isn't as close as mine. My hub to fender measurements are around 26.5-27, so it's way more lift than I anticipated and I guess I can't be surprised that I'm having this problem. I'm also still going to have to lengthen the Blazer bump stops somehow. You really lucked out on the height you're at when it comes to that!
I'll watch your build thread to see if it works out for you. I think an adjustable panhard will increase the contact between the drive shaft and the gas tank skid. My hub to fender is around 25.5", so I'm surprised yours is so tall. The blazer bumpstops worked really well for me, but I can see them needing to be extended on your skyscraper!
DAT FLEX. :cheers:
Whose badass trike is that?
It's my buddies brothers trike. That thing gets sketchy and it's super bumpy, but it was a blast.
Went wheeling yesterday, but ended up getting lost amid a bunch of mining trails that dead-end instead of finding the actual trail. Oh well, still a fun day.
DSC01712 by FR4R, on Flickr
Got some good pictures on this obstacle, couldn't get up it though due to lack of rear locker...
DSC01720 by FR4R, on Flickr
DSC01726 by FR4R, on Flickr
DSC01728 by FR4R, on Flickr
This rig was on 42s, Fox shocks on all 4 corners, I'm assuming it was spooled front and rear, and had a diesel hiding under the hood. He made the off-camber left line look pretty easy.
DSC01741 by FR4R, on Flickr
Had some nice views too.
DSC01751 by FR4R, on Flickr
Moar pictures.
Ran Moody Hill and Crystal Mountain west of Fort Collins with [MENTION=82211]TCMach[/MENTION] and his roommate. Had some fun, pushed some wheeling comfort limits and nothing broke, that's a win!
<a href="http://www.flickr.com/photos/92196326@N04/9583392439/" title="DSC01852 by FR4R, on Flickr"><img src="http://farm3.staticflickr.com/2892/9583392439_5b96dfd7c4_c.jpg" width="800" height="532" alt="DSC01852"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9586181134/" title="DSC01855 by FR4R, on Flickr"><img src="http://farm8.staticflickr.com/7412/9586181134_359f2df56e_c.jpg" width="800" height="532" alt="DSC01855"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583389093/" title="DSC01866 by FR4R, on Flickr"><img src="http://farm8.staticflickr.com/7350/9583389093_6b0b798ff1_c.jpg" width="800" height="532" alt="DSC01866"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9586176986/" title="DSC01876 by FR4R, on Flickr"><img src="http://farm4.staticflickr.com/3719/9586176986_96310d0036_c.jpg" width="800" height="532" alt="DSC01876"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583383467/" title="DSC01886 by FR4R, on Flickr"><img src="http://farm8.staticflickr.com/7336/9583383467_87c8dd9c8a_c.jpg" width="800" height="532" alt="DSC01886"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583381099/" title="DSC01901 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5522/9583381099_a02769acd8_c.jpg" width="800" height="532" alt="DSC01901"></a>
At the bottom of the Quarry
<a href="http://www.flickr.com/photos/92196326@N04/9586213002/" title="DSC01916 by FR4R, on Flickr"><img src="http://farm4.staticflickr.com/3813/9586213002_f10785e72a_c.jpg" width="800" height="532" alt="DSC01916"></a>
Lining up
<a href="http://www.flickr.com/photos/92196326@N04/9586211718/" title="DSC01920 by FR4R, on Flickr"><img src="http://farm4.staticflickr.com/3671/9586211718_a5399aa59c_c.jpg" width="800" height="532" alt="DSC01920"></a>
Up
<a href="http://www.flickr.com/photos/92196326@N04/9586210604/" title="DSC01923 by FR4R, on Flickr"><img src="http://farm3.staticflickr.com/2879/9586210604_c63a352c51_c.jpg" width="800" height="532" alt="DSC01923"></a>
Up
<a href="http://www.flickr.com/photos/92196326@N04/9586209316/" title="DSC01929 by FR4R, on Flickr"><img src="http://farm3.staticflickr.com/2827/9586209316_047bc15065_c.jpg" width="800" height="532" alt="DSC01929"></a>
And away...
<a href="http://www.flickr.com/photos/92196326@N04/9586208238/" title="DSC01938 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5513/9586208238_4be073f0a9_c.jpg" width="800" height="532" alt="DSC01938"></a>
Same ledge. Tried real hard to run Tyler over so I could pick parts off his truck but he moved too fast.
<a href="http://www.flickr.com/photos/92196326@N04/9586207048/" title="DSC01943 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5533/9586207048_da1b060111_c.jpg" width="800" height="532" alt="DSC01943"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583415615/" title="DSC01945 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5469/9583415615_8453faa90a_c.jpg" width="800" height="532" alt="DSC01945"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583414509/" title="DSC01951 by FR4R, on Flickr"><img src="http://farm3.staticflickr.com/2864/9583414509_9efe9c5cd1_c.jpg" width="800" height="532" alt="DSC01951"></a>
Had to break the pictures up into 2 posts...
Another ledge/climb
<a href="http://www.flickr.com/photos/92196326@N04/9586204102/" title="DSC01955 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5334/9586204102_f1e3c2817e_c.jpg" width="800" height="532" alt="DSC01955"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583412383/" title="DSC01980 by FR4R, on Flickr"><img src="http://farm4.staticflickr.com/3800/9583412383_7f9a7a6021_c.jpg" width="800" height="532" alt="DSC01980"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583449117/" title="DSC02001 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5331/9583449117_2478484484_c.jpg" width="800" height="532" alt="DSC02001"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9586236026/" title="DSC02016 by FR4R, on Flickr"><img src="http://farm4.staticflickr.com/3766/9586236026_2bc0ae0b72_c.jpg" width="800" height="532" alt="DSC02016"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583444757/" title="DSC02020 by FR4R, on Flickr"><img src="http://farm3.staticflickr.com/2809/9583444757_e751f0e059_c.jpg" width="800" height="532" alt="DSC02020"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583443407/" title="DSC02024 by FR4R, on Flickr"><img src="http://farm8.staticflickr.com/7411/9583443407_c718c5f67e_c.jpg" width="800" height="532" alt="DSC02024"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9586230596/" title="DSC02034 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5463/9586230596_39835cc906_c.jpg" width="800" height="532" alt="DSC02034"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583439435/" title="DSC02037 by FR4R, on Flickr"><img src="http://farm4.staticflickr.com/3785/9583439435_9bafd5a428_c.jpg" width="800" height="532" alt="DSC02037"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9586228784/" title="DSC02041 by FR4R, on Flickr"><img src="http://farm6.staticflickr.com/5449/9586228784_1cf4b20a8c_c.jpg" width="800" height="532" alt="DSC02041"></a>
<a href="http://www.flickr.com/photos/92196326@N04/9583437637/" title="DSC02044 by FR4R, on Flickr"><img src="http://farm3.staticflickr.com/2833/9583437637_3108ce9164_c.jpg" width="800" height="532" alt="DSC02044"></a>
Nice shots dude, I would love to make a trip up there and hit some trails with yall some time. What part of CO are you in?
Thanks man. I'm up North in Fort Collins going to school, as is [MENTION=82211]TCMach[/MENTION]. If you ever make it up here we would be glad to run some trails with you.
These pictures are bomb!!! So awesome! [MENTION=88391]NateMob[/MENTION] I have a couch and your more than welcome to it if you ever come up haha
nice build you got going on there. How you liking the those extended billies from TT. I love mine but i really wish they had a little more dampening but the they are damn smooth. I am gonna have to make a trip out there to denver and come meet you guys sometime. Probably have to coordinate with Nate and get out there around the same time frame.
Thanks man! The extended 5100s are great so far. I agree they are super smooth. Definitely let me know if you make your way out here, we could get a good group together for a trail run.
