JayRolla
I also run these shocks and DID MODIFY the shock tower. I believe Steve at SS told me that if you are hard core wheeling and fully stretching a lot that the larger diameter helps you get more articulation, the stock strut tower on the landcruiser was made to adjust and have more movement, he highly suggested I do it. If you email Steve I'm sure he will explain everything and may also he has all the hardware you need, I can probably look up the instuctions he gave me also. Gave what bit to use and everything.
