extended brake lines needed with lift ?
No you do not need it, I'm running land cruiser 8wraps with out extended brake lines, don't waste your money on it
IMO: If you disconnect your sway bar off road, which gives huge articulation without getting tippy, you will be pushing your luck without an extended brake line. It's cheap insurance for loosing your brakes on the trail.
