11-26-2012, 08:12 PM
Location: Stationed in Camp LeJeune, home is Conover, NC
Torque Specs.
See this thread for a more in depth version of torque specs.
Torque Specs and Service Information Revisited.
I pulled this of the TTORA site. Don't know if its still up there or not.
It has the specs for the 2/3RZ, and the 5VZ. Make sure you read it right!!
I know these are for a Tacoma, but the majority Of them will apply to our 4Runners, with the exception of the leaf spring and u-bolts.
If there's something you want to correct, PM me and I'll be sure to add it/change it as necessary.
Torque specifications
Engine:
Throttle body mounting nuts/studs: 13 ft-lbs
Spark plug: 14 ft-lbs (2RZ/3RZ), 13 ft-lbs (5VZ)
Oil drain plug: 27 ft-lbs
Engine mount to frame: 28 ft-lbs
Engine mount to block: 38 ft-lbs (2RZ/3RZ), 32 ft-lbs (5VZ)
Head bolts: 29 ft-lbs + additional 90° + another 90° (2RZ/3RZ)
Head bolts: 25 ft-lbs + additional 90° + another 90° , recessed 13 ft-lbs (5VZ)
Main bearing caps: 29 ft-lbs + additional 90°(2RZ/3RZ), 45 ft-lbs + additional 90° (5VZ)
Exhaust manifold: 36 ft-lbs (2RZ/3RZ), 30 ft-lbs (5VZ)
Intake manifold: 22 ft-lbs (2RZ/3RZ), 13 ft-lbs (5VZ)
Air Intake Chamber: 15 ft-lbs (2RZ/3RZ), 13 ft-lbs (5VZ)
Crankshaft pulley bolt: 193 ft-lbs (2RZ/3RZ), 217 ft-lbs (5VZ)
Oil pan bolts: 9 ft-lbs
Rear main oil seal: 9.7 ft-lbs
Rear end plate: 14 ft-lbs
Starter mounting bolts: 29 ft-lbs
Pressure plate to flywheel: 14 ft-lbs
Flywheel to crankshaft bolts: 65 ft-lbs (2RZ), 19 ft-lbs + additional 90° (3RZ), 63 ft-lbs (5VZ) ~USE LOCTITE~
Flexplate to crankshaft bolts: 54 ft-lbs (2RZ/3RZ), 61 ft-lbs (5VZ)
Drivetrain:
Lug nuts: 83 ft-lbs
Transmission bellhousing to engine: 53 ft-lbs
Transmission crossmember to frame: 48 ft-lbs
Transmission mount to crossmember: 14 ft-lbs
Transmission mount to transmission housing: 48 ft-lbs
Transmission housing to transfer adapter: 27 ft-lbs
Transmission housing to transfer case: 17 ft-lbs
Shift lever retainer: 29 ft-lbs (2RZ/3RZ), 13 ft-lbs (5VZ)
Transmission drain and fill plugs(MANUAL TRANSMISSION): 27 ft-lbs
Transmission oil pan: 65 in-lbs (A340)
Drain plug: 15 ft-lbs (A340)
Companion flange nut to transfer output shaft: 87 ft-lbs
Transfer front to rear case: 21 ft-lbs
Driveshaft flange bolts: 54 ft-lbs
Driveshaft center support bushing to frame: 27 ft-lbs
Driveshaft center support bearing: 134 ft-lbs to set, then loosen, then 51 ft-lbs
Suspension/Steering
FRONT:
Brake caliper mounting bolts: 90 ft-lbs
Brake caliper banjo bolt: 22 ft-lbs
Steering knuckle to lower ball joint: 59 ft-lbs ~USE LOCTITE~
Outer tie-rod to lower ball joint: 67 ft-lbs
Lower control arm to frame (alignment cams): 96 ft-lbs
Lower control arm to shock absorber: 101 ft-lbs (may vary with aftermarket equip)
Lower control arm to swaybar end link: 51 ft-lbs
Lower ball joint to lower control arm: 112 ft-lbs
Upper ball joint to upper control arm: 80 ft-lbs
Upper control arm to frame: 87 ft-lbs
Shock absorber upper mount (3 bolts): 47 ft-lbs (may vary with aftermarket equip)
Shock absorber center nut: 22 ft-lbs
Swaybar to swaybar end link: 22 ft-lbs
Swaybar brackets to frame: 19 ft-lbs
Differential front mount to frame: 101 ft-lbs
Differential rear mount to frame: 64 ft-lbs
Ring gear bolts: 71 ft-lbs
Differential drain plug: 48 ft-lbs
Differential fill plug: 29 ft-lbs
Axle shaft hub nut (ADD): 174 ft-lbs
Free wheel hub inner lock nut (manual hubs): 203 ft-lbs
Axle shaft inner hub safety bolt (manual hubs): 13 ft-lbs
Hub body to axle hub (manual hubs): 23 ft-lbs
Hub body cover (manual hubs): 7 ft-lbs
REAR:
Backing plate to axle housing: 50 ft-lbs
Shock absorber to axle: 53 ft-lbs
Shock absorber to frame: 53 ft-lbs
Axle u-bolts: 90 ft-lbs
Front leaf spring mount: 115 ft-lbs
Shackle bolts (both): 67 ft-lbs (may vary with aftermarket equip)
Leaf spring centering pin: 33 ft-lbs
3rd member to axle housing: 18 ft-lbs
(with e-locker), 54 ft-lbs (w/o e-locker)
Ring gear bolts: 71 ft-lbs (with e-locker), 92 ft-lbs (w/o e-locker)
Carrier bearing caps: 83 ft-lbs (w/o e-locker)
E-locker acutuator to 3rd member: 20 ft-lbs
Differential drain & fill plugs: 36 ft-lbs
STEERING:
Steering wheel set nut: 26 ft-lbs
Inner tie-rod to rack: 76 ft-lbs
Tie-rod end lock nut: 41 ft-lbs
Steering rack mounting clamp: 123 ft-lbs
Steering rack vertical center mounting bolt: 123 ft-lbs
Steering rack horizontal mounting bolt: 141 ft-lbs
Miscellaneous:
Seat mounting bolts to body: 27 ft-lbs
Seat belt: 30 ft-lbs (all mounting points)
Body mounting bolts: 48 ft-lbs
Conversion Factors:
1 ft-lb = 12 in-lb = 1.35582 Nm
Just thought that might help.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
11-26-2012, 11:50 PM
nice info, i usually check the service manual which has most of them in it, but this is a good quick reference. My problem is, that in 1/2 the places where a torque value is specified, you can't even fit a torque wrench in there so i usually just guess.
03-12-2013, 06:15 PM
good info, thanks!
03-12-2013, 10:32 PM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
As per request, thread stickied.
03-12-2013, 11:43 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Good thread.. ought to come in handy! Mind making the different sections bold so they show up better. It's hard to tell where they start and end.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
03-13-2013, 09:51 AM
Fixed for ya.
03-13-2013, 10:09 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Originally Posted by Doc2012
Fixed for ya.
Much better! Thank you
03-13-2013, 03:27 PM
Real Name: Nate/Nathan
Sweet! I could definitely use this!
The Name is Nate. (n8) I own a 2002 4Runner Sports Edition. Feel free to PM me, about anything.
My Build: http://www.toyota-4runner.org/3rd-ge...od-thread.html
03-13-2013, 03:29 PM
Awesome thread Doc! Torquing is probably one of the most important jobs someone can do aside to repairing and replacing. Good info; good idea to make it a sticky.
2002 "Stormtrooper" 4Runner
Tacoma Bilstein 5100s | Eibach/Toytec Springs (Front) | FJ Springs (Rear) | Tundra 13WL Brake Swap | Much More...
03-13-2013, 09:52 PM
Perfect. Just what I was looking for.
Thanks
03-25-2013, 12:46 PM
Originally Posted by BrianSD_42
Doc this is a really great thread with very useful info. I will use it myself in the future no doubt BUT it doesn't belong on the main 3rd gen page. It should be put within the already stickied 3rd Gen technical documentation page.
If someone thinks I'm wrong then fine but I just don't see how this info is so special it wouldn't be in that already existing sticky (which has taken years to build).
Link ---> 3rd Gen FAQ, Tutorials, & Documentation Reference
// nothing personal
Nothing personal taken.
If I may just put my .01 in, and feel free to correct me if I'm wrong, but, IIRC the 2/3RZ and 5VZ were in the 95.5-04 model years, which encompases more of the 3rd generation 4Runner and 1st generation Tacoma.
My intent here was to provide a quick reference, rather than having to dig through a thread just to find the torque specs of a particular bolt.
If the mods feel it should be moved into the other thread, then by all means, please do so. I have these on my iPhone in my notes so that I can pull them up anytime, but others might prefer to look at a bigger screen.
03-26-2013, 01:48 AM
I say leave it so when I have oil and gunk all over my hands I don't need to dig to find torque specs. Lol
03-26-2013, 11:07 AM
Real Name: Instagram: briansd_97r
I really do think this is a great thread so I hope I didn't offend with my suggestion.
It is simply a difference of opinion.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
03-26-2013, 01:18 PM
Absolutely not. If I made it seem like that, I apologize. I just wanted to let you know why I thought it should be stickied.
03-26-2013, 03:43 PM
Doc,
Thanks for this super useful sticky. It was annoying having to google this info.
Would it be possible to add fluid/oil amounts and types to this.
IE: Engine, Trany, Diffs etc...
I dont know these things off hand but would be willing to search around to help compile something.
2000 "The Silver Legacy 2" Highlander Edition, 5speed 4x4
2000 "The Silver Legacy" Highlander Edition, 5speed 4x4 RIP
1996 Stellar Blue 5 Speed Sold
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
torque specs on lbj
WHORERUNNER |
3rd gen T4Rs |
11 |
09-22-2018 08:45 PM |
OEM Torque Specs
SAC-CA-Runner |
3rd gen T4Rs |
4 |
03-11-2013 10:07 PM |
Torque specs
rocket67 |
5th gen T4Rs |
6 |
12-13-2012 09:47 PM |
Torque specs?
Blackdot |
3rd gen T4Rs |
4 |
06-21-2011 03:54 PM |
Torque Specs
cwapps |
Maintenance/Detailing |
0 |
10-04-2008 05:27 PM |
