my tire carrier build
mien4x4
so i didnt want to send $ that i dont have on a bumper with tire carrier so i build one i spent $100 for materials and use some scraps i found in my backyard:lmao:
2 2x2 3/16'' angle iron and a tow hitch for a honda delso
weld the angle iron together to make square tubing
cut some off for got the length
weld together
the piece i cut
2 1.5'' angle iron for the vertical bar
piece of a tow hitch i cut off for the tire mount
1'' square tube for the support bar
finish with the tire on and test swing out
all i need is a lock pin for it
I always like to see a new idea, and this isn't a method I've seen before. Only downside I can see is keeping the factory hitch kills a bit of the departure angle, but probably the easiest method I've seen done with out a full bumper build or lots of body modification to move it to the Surf's location.
yea thats the only bad thing i thought to about the tow hitch is the departure angle the reason why i wanna to have a tire carrier is because i up graded to 35s and theres nowhere to put it and i didnt want to spend money on a bumber with a carrier because i want to regear first so yea
Good idea. I think I might do something similar but turn the tow hitch upside down, delete the stock bumper, and add some plate or tube to protect the corners.
love the idea. does it sag at all on the other end and where are you putting the pin?
looks like all you need to do is box up the long tube, find a new place for the license plate and paint the thing.
honestly I think I'll try this. great job :)
that what i should of done the first time when i rewelded my hitch to match my body lift:wtf:
yea it sags down a 1/2'' i say but i thinkk its because the hinge parrt they put plastic washers and thats where its kinda loose from ima try to put real washers and see what happens and for the pin i dont no yet thats the only thing i dont have but proly just gona put it on the end that come out
I was thinking you could build a bracket on the drivers side of the hitch.... a 3 sided box that the long tube could settle into. then just get yourself a positive locking pin and bolt from the top. or box in the end and drill a hole in it and use the locking pin from the side.
yea man sounds good just depends on how lazy i am now lol i was thinking about using a old fashion gate latch where u lift off the lock hole and slide lol idk yet thanks for the idea man
haha don't be lazy... its probably the easiest thing you've done on this project.
I got the idea for the pins from the H1 brush guard.
nice work! Is that the cheap-o harbor freight welder? I've heard good things about the harbor freight welder.
