01-12-2013, 08:58 PM
Dual USB Port – Installed in place of the Cigarette Lighter – 3rd Gen
I replaced the cigarette lighter with this Dual USB Port.
It required that the hole be enlarged just a tiny bit. I used a dremel tool to accomplish that. I slipped a tiny screwdriver into the electrical plug and saved the factory clips and they slid right onto the new posts (cover in a little electrical tape - just to be safe).
There’s a metal part that protects the dash from a hot lighter – I didn’t put it back because I didn't want to enlarge that hole. I figured if I ever want to return it to stock – I can put the metal guard back in place.
The USB Ports come with a black plastic cap that I didn’t use – but if you do a lot of wheeling I’d suggest it as it will help keep the dust out. I also didn't use the backing plate that it comes with.
Blue Sea Dual USB Charger Socket w/Watertight Cap
Amazon.com: Blue Sea Dual USB Charger Socket - 2 USB Ports w/Watertight Cap: Sports & Outdoors
Thanks to
@ Asmara
for the idea
FRONT
BACK
EXTRA PARTS
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
01-13-2013, 12:35 AM
So what is the purpose of this? Just for charging?
97 V6 4X4 AT; ICON 2.5 EXT TRAVEL COILOVERS / SS 1.2 REAR; AUSSIE LOCKER; TC UCAs; SAVAGE OFFROAD SLIDERS AND SKID PLATES; ARB BUMPER; WARN WINCH; LOTUS CONTROL ARM SKIDS; DECKPLATE/ISR; 265/75/16 BFG KM2
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-13-2013, 01:03 AM
Yup, lots of things have USB cables with power source adapters, which you could leave at home if you had USB's for charging. Great for roadtrips, you can charge 2 phones at the same time, and still have the GPS plugged into the lighter/powerpoint.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
01-13-2013, 02:29 AM
Real Name: Russel
Real Name: Russel
Wow...great idea! I never thought about doing this...but now that I see it in your T4R...it's like..."wow, why didn't I think of that?"!
Yea, I can charge my i-Phone and i-Pad at the same time...and still have two 12V adapters accessible for my wife's heating blanket (please...don't ask) and my son's DVD player. Heck, everyone's happy on the next road trip!
Thanks TRD 4RNR for sharing this with us.
Reason: Posted wrong user name...oops!
01-13-2013, 02:57 AM
much cleaner than the adapters I've been using.
01-13-2013, 05:30 AM
I just plug a two usb port piece into my cigarette lighter, no mods needed.
01-13-2013, 09:43 AM
That is great!
What did you tap for power?
01-13-2013, 10:54 AM
Originally Posted by RussToy
Thanks IanB for sharing this with us.
Not my install, just commenting on TRD 4RNR's.
01-13-2013, 11:03 AM
Real Name: Russel
Real Name: Russel
Thanks for catching my mistake...it was late! I fixed it...
Thanks again TRD 4RNR for sharing!
01-13-2013, 12:09 PM
That's what we have been doing as well, but the last one smoked itself and they irritate me the way they don't sit flush with the dash. So if this lasts longer and looks better for that price, i'm in.
01-13-2013, 01:17 PM
pretty cool mod it looks super clean and OEM! I used this low profile plug that almost looks flush.
01 SR5 SPORT
Many mods done, Many more to come
Build Thread
01-13-2013, 03:19 PM
The $30 car charger racket has finally been broken!!! It's about time, what a scam that was.
Nice install, OP.
2000 4Runner SR5 2wd | 3.4L V6 Auto | Millenium Silver Metallic | 218,000 miles, 1 owner | Sonoran Steel 3.0 ('99 coils) | Tundra 199mm brake upgrade - Brembo blanks & Akebono pads | Koyo 1998 radiator | Bridgestone Dueler A/T 265/75/16 tires | Hella MicroDE fogs | Rear-facing aux lights | Deckplate mod | Fiamm Freeway Blaster horns | Curt Class III receiver | SilverStar Ultra bulbs
01-13-2013, 03:26 PM
Real Name: Mr. Allen
Thats a great mod. Id like to do it but I've got the older version with only one power outlet. Is there a way to switch out just the compartment so i have 3?
01-13-2013, 10:11 PM
This is what I did. Hot wired with an on/off toggle switch and an inline fuse near the battery. I bought the power outlets from walmart. There is a debate on my set up, but it has been over 2 years, used daily and works perfect, no issues. Pics are attached in link.
Installed two power outlets - YotaTech Forums
01-13-2013, 10:28 PM
Yessir - check this post:
How-To: 99+ Center Dash Conversion with Wiring
It's pretty simple and the write up is straight forward. As long as you are comfortable putting wires into a butt connector and crimping them, you shouldn't have any trouble.
