Weird headlight issue! Help
Hey guys I've recently noticed some issues with my 4runners (drl equipped) headlights. Here are the symptoms: driving lights work, lows do do not, highs will flash when the stick is pulled back, but will not stay on when pushed forward into the on position. Also all the exterior and interior work when the rotary part of the switch it turned on. I've double checked all fuses and relays and the bulb themself. The only thing I can think of left is the switch itself but would like a second opinion befor ordering a high priced new one. Has anyone else experienced any issues like this? Any help is appreciated.
http://tacoma.site40.net/4Runner_96-...i/020hldrl.pdf How did you check the DRL main relay (D8)? That's the next suspect, and checking that is a non-trivial exercise...and you really CAN't check it, unless the switch, IS in fact, working. So, if you did check it, you would already know whether the switch is working. Oh, welcome to the forum! |
Relay locations: http://tacoma.site40.net/4Runner_96-...c/relayloc.pdf Other components locations http://tacoma.site40.net/4Runner_96-...tric/parts.pdf After a quick look, yes main relay is by the column. There is a diode for the DRL under there but I don't think it could cause your condition. |
3 Attachment(s)
Well, between yesterday and today the taco site took down their on-line FSM and Wiring manuals that I have been linking to ever since ncttora took theirs down. So now I will attempt to post attachments:
Wiring diagram--DRL headlights:Attachment 83521 Attachment 83522 Attachment 83523 |
Cool. I can see them. Can somebody out there confirm that others can see them? Thanks.
Or does anybody know an on-line source that still works? I fear Toyota killed them all. Even the wayback site got cleaned out. |
Yup I can see them. Thanks again
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
