Replace Side Mirror Enclosure or Glass?
tomar
Hello - I cracked my driver's side mirror. The dealer told me I can order a new mirror glass for $50 but suggested that I pay him to replace it due to the delicate nature of the install. I can find aftermarket or used mirror enclosures online but from what I've read, I would have to remove the door panel to install. Is it easier to replace the mirror glass or the entire mirror enclosure?
dealer sounds correct to me. I'd let them do it if they price it right. The attached PDF shows how it works. Note the change in design for the 2000 year.
I'm curious if the new mirror comes with the black trim or is it only the glass with no black trim?
Yes you need to remove the door panel to change the entire mirror housing.
BFAD replaced his in his build thread. Don't know where he got the glass. Link:
http://www.toyota-4runner.org/3rd-gen-t4rs/97515-small-tribute-my-original-runner-bigfishallday-s-97-toyota-4runner-build-thread-7.html#post1322443
I replaced the driver's side glass on my 1997 a couple of years ago. If I recall correctly, I bought the glass on Amazon for about $15.00. Wasn't too hard to replace and is still going strong.
My daughter broke her mirror so I bought a new one at the dealer and then a few months later I find we have an LKQ salvage yard a short distance away So I go to LKQ and find a complete mirror assembly (same color) for 19.00 plus 8.00 core charge, I was pissed that I spent 50.00 on a piece of glass.
Replacing the glass is not a bad job at all. I removed the assembly and did it on the bench. Removing the door panel is really easy, do it yourself and save the money. I now have 3 desert dune mirror assemblies.
Let me just say that I can't remember the last time I posted something on any forum and received this many helpful responses. Thank you all.
badattitude - thanks for the instructions. The dealer (really a guy who works in the service dept.) told me that the mirror glass comes with the black trim and the plate that the glass is glued to. If I understood him correctly, I have to pop the plate (with the glass) out of the housing without breaking it. However, the instructions seem to indicate that the glass does not come with the back plate. I heard that these service guys are on commission so I'm always skeptical when they tell me to let them do it. He said the mirror costs $50 and the install will be about $100. I tried to get him to tell me how to remove the plate, but he didn't.
Kurtis - thanks for the link. I may need to refer to this if I decide to just buy the glass only.
traffic61 - $15 sounds a lot better than $150. I assume you scrapped the broken glass and adhered the new glass to the plate underneath?
mmml4 - Was the glass you bought from the dealer already adhered to the plate or was it just the glass only?
I was trying to save time and money. I've pretty much ruled out spending $150 for the dealer to do it.
It was just the glass only. I just unplugged the old one (heated mirror) and scraped it off and stuck the other one on.
It was a fairly painless process. I pulled the big garbage can underneath the mirror housing and began the removal of all of the mirror pieces. I then had to remove the adhesive from the backing plate. I think I used some form of adhesive remover and elbow grease. After the backing plate was clean, I went over it with some alcohol to remove any grease before I attached the new mirror's adhesive pads. Then I just pressed it into place firmly. Hope this helps.
Check out ebay, I paid $5 shipped for my passenger's side. didn't take long to remove fragmented pieces but definitely have safety glasses and gloves on.
Now if I can just get the cover off and put my led covers:ballchain:
