RS3000 VIP alarm locations - 98 SR5...HELP!
bergeron37
Ok so heres the deal. I installed the dealer-installed fog lights that came with some '98 models. Found a set on ebay.
Now I can't get the battery to hook up without the alarm going off - I do not have a key fob, there is no red-light sensor anywhere, and the "brain" of the alarm is not under the driver seat.
It has been 48 hours now and my truck is still sitting in my driveway immobilized because of the ****ing kill switch on the RS3000 VIP system.
How many locations can the brain be in? The dealer told me if I can find the brain and simply unplug the harness, then I should be good to go in terms of hooking up the battery.
I know "the search function is your best friend" - I've searched for the last 2 days and have had no luck cycling the key in the ignition or the drivers side door. I need help, pics are coming soon.
1st pic: no red light sensor ever present, bought truck private party 6 months ago and this spot was always empty
2nd pic: under driver seat, i've slit the rug and looked under - nothing
3rd pic: driver side kick panel
4th pic: kick panel close-up
Do you see anything that looks like the brain or the valet toggle switch
sorry bud. you're kill switch isn't in the same place as my 96's. you would have had to disconnect it to pull the kick panel all the way out.
on a seperate note it looks like someone has done a little wiring on yours. do you have an aftermarket stereo? that ground looks added. maybe it was tucked up in the kick panel somewhere?
I'm really not sure how many different locations there were for the brains or switches. I only have my two 4runners to compare it to. (96 and 02) You're situation looks different then both of mine.
edit: also, its quite strange that cycling the key isn't working for you. do you have power to you're accessories when you turn the key or just nothing? or will the key just not fire the motor?
Yes I have an aftermarket stereo thats what the blue wire is (amp remote turn on) and the ground I believe. I got the lights on the dash to light up when I started cycling the key in the ignition but never got the alarm to turn off or the engine to turn over.
Is the alarm ECU really that small that I may have missed it under the driver seat?
Dude stop taking things apart.
Turn the key in the ignition 2x. The alarm will reset and you will be able to start the car. You do not need a key fob.
It really is that easy.
I thought I explained that I tried that. I will give it another shot in the morning but I have tried doing that multiple times with no luck.
trust me I have read every thread on this issue so its not like I'm ignoring similar issues previously solved. At this point i would rather unplug the entire alarm system
Try looking for the chirper under the hood and back trace the wiring to the module. The chirper on mine was beside the battery wrapped in foam.
Does this look like it could the chirper? Don't recall having this on my 2000. There are 2 wires (red/black) that run from this through the firewall directly to under my steering wheel. I don't see the ecu there but I am going to keep looking
Breakthrough
This picture shows what looks to be both the keyless entry module as well as the alarm ECU zip-tied under the steering wheel column. The keyless entry module is already unplugged (which makes sense considering I never received the key fob) and there looks to be a valet switch of some sort. I will update when hopefully this is resolved
Wow that was an annoying weekend. Big thanks to everyone who provided insight. I took the keyless entry module out completely, disconnected 2 of 3 harnesses that go into the alarm ECU (I left the door lock one in there mainly because I couldn't get it out). Truck started right up, no issues at all and now I never have to worry about that ****ing alarm going off again next time I need to disconnect the battery.
I don't understand why none of the key cycling tricks worked for me, I spent 2 days trying it with no luck. I should have just looked for the ECU from the get-go instead of trying to turn the alarm off with key.
Anyway thanks again - if anyone needs the keyless entry module for the RS3000 VIP system let me know hahaha
Actually I think I might want it. I didnt know that was a seperate module from the security ECU. How much would you want for it?
Honestly just cover the shipping cost - shouldn't be more than $10. I'll take a few more pictures later on today and PM them to you just so we make sure it is actually what you are looking for. I'll be in touch
if 1985taylor doesn't take it, I'll be glad to take it off your hands, I've been looking for one to replace mine
Let me know and thanks!
Brian
Hey guys, I am working with 1985taylor1925 right now to see if he wants it. I might have been wrong about it being the keyless entry module as it reads "shock sensor" on it. Picture attached, if he doesn't want it I will move down the line in terms of who contacted me after him. Sorry for the confusion.
Ya, I dont think that is the keyless entry module. I think the keyless is part of the VIP module/ECU. But maybe someone else can shed some light on what the shock sensor is for?
Hello everyone,
I know I am late to the party with this problem, as it is 2019 and the vehicles discussed in this thread are from 96-02.
I drive a 1998 Toyota 4Runner SR5 Limited. It currently has 230,000 miles and counting (Just changed the timing belt and water pump). I bought this amazing truck back in January of 2014, and put over 80,000 miles on it so far.
I had a remote start installed one year after owning the vehicle. The remote start was installed by a geeksquad technician and everything functioned perfectly. I never got the original keyless entry remote from the owner i bought it from.
Everything was working fine, and my vehicle has been a charm.
Here is the problem:
When i was driving home from work yesterday, i noticed a small whining noise, like an alarm buzzer going off. I didnt think anything of it. I got home, and parked it in the driveway. A few minutes after going in my house, i hear the alarm buzzing noise again, only louder. From the other vehicles ive owned, this can indicate that i left the lights on and the car is off, and or the battery is low.
I turned my car on after making sure that i did in fact turned the lights off originally when i got home (lights were off). I heard the noise still so i decided to take it around the block for a test drive. About three minutes into the test drive, not only was this annoying alarm going off without stop, the horn started going off without stop as well. I was freaked out. Parked back at home and immediately took the negative terminal off of the battery.
Upon reconnecting the negative terminal, the alarm started buzzing again, but the horn was not.
At this point, i realize that it was a security system that i had no knowledge of that even was installed in my vehicle. Directly to the right of the driver seat, there is a storage console with a few buttons farther up towards the radio, (ETC power, back window roll up/down, an unmarked switch that goes up or down and i have no idea what it does, and a toyota security panel- no button no switch- that is now lit red)
There is a toyota security system box located directly under the drivers seat. It could have gotten wet as a bottle of water spilled the day this problem occurred and shorted a fuze in that box. Im a bigger guy, tall and big hands, large torso, so it was very difficult for me to get at. I saw no button on the box, but there are three connectors to this box. i disconnected the connectors to this box, and the alarm stopped, but then my truck would not start.
There is a fuze box located directly to the left side of the steering, just down a bit, which i pulled the panel off and started reviewing the labels on the inside of the panels. I did not see any fuze marked with security or alarm, but i did see ones for ing (ignition i think) acc (accessories) etc. I let the car run with the alarm on and started pulling some of those fuzes out and replacing them immediately after ruling out that they were not directly related to the alarm. This resulted in nothing, as the truck was running and alarm continued to buzz.
I also spent a lot of time searching through this website forums and other forums on the topic.
Many people suggested closing and locking all the doors, and using the key to unlock and lock three times in a row and alarm would disarm. No result.
A lot of people claimed that there is a reset button located somewhere in the interior of the truck. The two most referenced locations were located under the dashboard, and or a by or under a kick panel. I spent a good hour searching these places for a button or kill switch, none of which were to be found on my vehicle. Again, I am a bigger guy and i moved my seat all the way back but could still barely fit to get a good look up there. I looked at multiple pictures and descriptions of where they found this button, but i cannot see it, and am convinced that there is none.
There were just as many people that claimed that if you enter the vehicle, close and lock all doors, and place key into ignition and turn from off to acc three times then start vehicle, alarm will reset. No result. Additionally, a similar amount of posts referred to something like that, only saying move key from off to on five times then start vehicle. This resulting in something happening like the dashboard lit up twice and the doors locked and unlocked twice, but the alarm remained going off.
Some people also claimed that if the battery is compromised and or not grounded correctly, that it could cause the same problem. The battery is good, as it was just replaced 6 months ago, and tested at 14 volts, but the grounding is messed up. Way back when i bought the vehicle it appeared that the grounding cable directly tied to my negative terminal was chewed by a rodent. I cut the tubing off of the wire, bought some new tubing, retubed and electrical taped properly. This worked great, but when i opened my hood up yesterday when the problem occurred, i noticed that it had fallen out of place. I will reground that cable today to see the effect, but i also have reason to believe that this is not the root cause.
The last thing i tried that i read in some threads was to turn the car off and on and leave a ten second period for each time turned on and turned off, three times in a row. I did this and nothing happened as alarm remained going off.
The only thing i can think of now is to have another set of eyes to check for that button somewhere before i cut the wire to the speaker for the alarm.
I am worried that if i cant do anything but cut the speaker for the alarm, i will cut the wrong wire and mess something up, as i do not know much about the electrical system itself in my vehicle.
The keyless entry and remote start appear to be working still even with the alarm triggered.
I guess my question is A) has anyone gone through this problem with the similar variables to my problem and B) has anyone successfully located and cut only the speaker of the alarm to disable the alarm noise.
