Monstaliner write-up
foxrider56
Ok so after coating my whole t4r in monstaliner a couple of guys requested I do a write up so here it goes:
Materials I ordered:
- 2 gallons of desert sand monstaliner
- 1 gallon of black monstaliner
- undercoating gun (spray or roll on application)
- 2 quarts of MEK
- Blue painters tape (base board’s version)
- 12x100 ft. clear plastic
- 80 grit sand paper
- Bulldog adhesion promoter (for coating plastics)
- chassis saver (for bare metal primer)
Other Tools needed:
- Power drill
- Compressor (if spraying on)
- Respirator
- A buddy to help
- palm sander
Prep:
- clean the area as best you can
- wipe down area with MEK
- Sand down all the areas you want to coat (careful not to strip to bare metal, just enough to remove clear coat)
- wipe down with MEK 2 times ensuring surface is clean of everything
- Tape all areas you don’t want hit with paint
Application:
I decided to spray it on vs. rolling because of a few reasons, time, I liked the texture better, and I had a compressor so why not?
The paint comes in different containers, the paint, the catalyst and the color (if not doing black)
Here is a video on how to mix the black paint
Mixing Monstaliner (Black) - YouTube
The tin table colored ones is a little different because you must add the color to the paint
- Once mixed I poured the paint into the gun and started spraying working from the top to bottom.
- I sprayed at 65 PSI (recommended 50-80) (they also say to reduce it with 4 oz. of MEK when spraying)
- spraying is extremely easy; you will get a hang of it as soon as you start spraying.
- Once done first coat clean gun and wait around 1 hour between starting again (paint should be dry to touch also clean the gun by spraying MEK through it)
- If working from the same gallon mix for 1 min. before starting second coat
- apply second coat making sure you hit all the areas you want (you should see texture now)
Here are videos I watched on how to coat by spraying
Predator Land Cruiser 6BT Install Part 7 Bed Liner - YouTube
MONSTALINER? Spray Application - YouTube
Clean Up:
-once done final coat they suggest to remove all tape right after (I waited about 10 min)
Clean spray gun with MEK
- If you get paint on un wanted area, use MEK and a rag and wipe off ASAP!
What I Used:
I used about 1.5 gallons of the desert sand and about 3/4 gallon of the black. with the desert sand I applied 2 heavy coats to entire body - all the parts I took off to paint black. for black I did 2 coats on most but 3 heavy coats on the bumpers.
Dry time:
- they say you can use it as little as 24 hours for light use but I waited 5 days before I started reassembling. also between coats the dry time is different between rolling and spraying
Any questions you can ask me or visit their site Monstaliner do-it-yourself roll-on truck bed liner outperforms Herculiner Bed Liner, Duplicolor and Rustoleum Road Warrior
or check out their Facebook page to see a bunch of pictures.
Also if you are coating plastic or bare metal there are a few different steps to do to make sure you get proper adhesion
some pics
Great man! I'd also like to request some more hi def pics, especially outside so we can see the quality in direct light.
Thanks!
I have to admit that when I first heard about this I thought it was dumb as hell.
Now I actually think it looks pretty sweet. :) Not sure it would make sense for everyone, but for those who plan on wheeling a LOT I could see how it makes quite a lot of sense. Looks pretty sweet. :)
How did you do the fenders? Are they aftermarket flares? Or did you mask them off and paint? If so, with black monstaliner? or regular paint?
You mentioned you sprayed because you liked the texture better than rolling. Can you describe what the differences are in texture spraying vs. rolling?
For the spray I just felt that it has a more fine texture and I dint want as rough as a surface, but when I did it I feel like I could control it how it went on with the spray application. You can just get a feel for how it works once you get going. I'm trying to find a picture of them next to each other But for some reason I can't. Also I figured when pros install it they spray it so it must have a more pridesional look
Let me know if you got anymore questions
I noticed in your pictures that you have some spots that look like "clumps". On the hood there are a few and on the driver side doors there is a few. The first time I saw your pics I noticed those spots where the texture wasn't uniform and I wondered if it was because you sprayed. Seems like that wouldn't happen if you rolled because it would all be smoothed out with the roller.
Could it be possible to use different size porous roller pads to achieve more or less texture?
Good eye, I ran into a problem when I did it where the material was too thick at first so it kept clogging the sprayer so specks were all over and there was a few spots where there were big glops from me accidentally having some pour out. Those problems are now fixed since in sanded it down and re painted. I feel rolling you can see the stroke marks if you are not careful but you can create your own texture with the speeed you go at
air compressor?
what size air compressor did you use? did you buy the shutz gun that they have on the site or go with a different model? did you have to worry about the CFM or have to use a regulator or filter on the gun/compressor when you did it?
i think you did a awesome job looks clean and tough at the same time. I plan on going from green to white when i do it just trying to decide on renting/buying a compressor or just rolling it on. saw another guy who rolled his on but like the texture you got from spraying.
im not quite sure the size of the compressor because its my friends down the shore, it was pretty big though like 50 gal maybe? and i did use the shultz gun and and i forget what psi i used im sorry it was quite some time ago, what i mianly did was follow a video on youtube of a guy spraying a landcruiser lime green. im sorry i forget all of the info. and for spraying it takes a lot of extra prep but in my opinion its faster becuase the spraying takes a few minutes, and you can rest and wait inbetween coats where for rolling it tkes forever to do the whole car and by the time you get done the first coat you have to go right into the second becuase it takes so long. its all up to you though
Can you give us an update on how you're liking the Monstaliner? How is it holding up to the elements?
I still love it and it's holding up pretty well, I haven't noticed and fading, but I did get a small chip on my front bumper , maybe because it came bare metal and all I did to prep it was some self etching primer . Overall I still love it and am thinking about doing the interior with it
