Kredence's lifted 4Runner
Kredence
Good evening. It has been a fun couple of days for the old Runner. She got new shoes on Thursday. 285/75/16 Falken-Rocky Mtn ATS 2. They ride great and just barely fit. Going to play in the dirt with them tomorrow.
Today, she got lifted. A week ago I met a guy with a lifted 4Runner at home depot. It had a nice lift and looked great. After a bit of chatting, I found out he had lifted it with Bilstein shocks, Tundra front springs and OME rear springs. Oddly enough, I had just read about the same lift the night before. He had great feedback and I decided on that lift. Now, with that said, there have been numerous changes in Bilstein's part numbers. It took a bit to make heads or tails of all of it. This is what I ordered:
2x Bilstein 5100 adjustable shocks. Part #24-188265
2x Bilstein rear shocks. Part #24-014786
1 pair of OME 890 rear springs. Also found as OME 2890
TRD Tundra front springs. Part #48131-AF090 (right) and 48131-AF100 (left)
I originally had read about this lift here. www.off-road.com
Bilstein front shocks Bilstein Adjustable 5100
Bilstein rear shocks Bilsteain rear
Right TRD Tundra coil Right Coil
Left TRD Tundra coil Left Coil
Part numbers:
The front shocks have had their part numbers revised twice.
BE5-6929-HO became BE5-6929-H1 and then 24-188265
The rears have been revised once.
B46-1478 became 24-014786
It turned out great. The ride is incredibly nice. It had blow factory shocks before this. The rear is a tad stiff but of no real trouble. I did set the front shocks on their lowest height settings. I will probably raise this one notch as the front end squatted more than I had hoped. So far I'm getting a 2" lift in the front and a 3" lift in the rear. The small shock adjustment should net me another 1/2" up front.
Prior to the lift
<img src="http://img.photobucket.com/albums/v429/xsiintegra/4Runner2.jpg" border="0" alt=" photo 4Runner2.jpg"/></a>
Post lift
<img src="http://img.photobucket.com/albums/v429/xsiintegra/Lifted4Runner.jpg" border="0" alt=" photo Lifted4Runner.jpg"/></a>
Bilsteins
<img src="http://img.photobucket.com/albums/v429/xsiintegra/Bilstein.jpg" border="0" alt=" photo Bilstein.jpg"/></a>
Enjoy,
Justin
A quick update:
I adjusted the front end today. I went up a 1/2" (one notch - second from the bottom) at the strut and picked up a full inch at the wheel in the front end. The total lift came in at 2 3/4" in the front (originally 1 3/4") and 3" in the rear. She sits from ground to fender: Front 37 1/4" - Rear 38"
<img src="http://img.photobucket.com/albums/v429/xsiintegra/FinalRunner.jpg" border="0" alt=" photo FinalRunner.jpg"/></a>
Looks sexual. Just watch your step down. lol.. And dont forget that you'll need an alignment after every time you adjust those struts. :rockon:
