Fairly certain that I've made a mess of this. I'm not happy with the way it has turned out for the moment as I don't have a good way to keep to coax pigtail from moving the fragile antenna solder joint.
Anyway, here are some pictures of the destruction for your entertainment
Couldn't get the connector to unscrew without damage to the wire soldered to it so I clipped the rear panel like on the slee website
Solder removed but since I couldn't get the connector nut off, I had to clip this solder joint to be able to removed the connector
Connector removed
Prepping the pigtail wire and connector
Soldering the PL-259 connector onto the RG-8X pigtail wire
Pigtail taking shape
A little dressing
Untangling the braid for a ground to CB chassis.
Chassis ground prepared and ring terminal soldered on
Ground strap attached
Hard to see it but center coax wire soldered to antenna connection wire that I clipped earlier
Power wire pigtail
And finally, the way the back currently looks.
The grommet I used isn't quite tight enough to provide a real strain relief for the wire and as such the wire can move which moves the internal connection. I think I have an idea to solve it but got tired of playing for tonight. If I can pin this down, ill seal up the hole with some sort of glue or sealant to add some additional strength and strain relief. Then on to the speaker and hoping this all actually works out well without compromising the radios communication range and what not.
17 Jayco Precept 35UP Motorhome - 18 Jeep Wrangler JLU - current
16 4Runner TEP KDSS - 15 4Runner Trail KDSS 4x4 - 06 4Runner V8 4x4 - ALL SOLD
97 4Runner Ltd. 4x4 - SOLD -
http://www.toyota-4runner.org/3rd-ge...d-project.html
