Turn Signal Mod: Aftermarket Bumper ~WRITE UP~
shootmymime
So after installing my trail gear tube bumper it left me with out a place to install my turn signals upfront. I was cheep and didnt want to spend any money on new turn signal housings so i decided to zip tie the old ones onto the bumper and run them like that for a bit. (hated the cheep ziptie look)
348C9919-F085-4CBA-8836-1314C1279F1F-15190-000007DF26763052_zps226d8e65.jpg~original
by doing some research i found out that tacoma guys like to install their their turn signals inside the running or aka parking lights.
so tonight i made a write up of the simple process.
It took about 30 min from taking the running lights of to installing the new turn signals in them and putting the tools away.
I used a high speed dremel with a rotary bit for plastic and the pencil wand for better control. Safety glasses as well.
I happened to have another tacoma that im parting out that already had these done to its running lights. but of course those light housings do not fit our 4runners.
C847B572-D592-425D-B32B-5FF5E107B010-161-000000077F4A6190_zps968b65b3.jpg~original
If you look close you can see the 1st hole i made to copy the tacomas housing. but quickly realized that it would not work because our housings are much thinner and the bulb bottoms out before the socket will touch the housing to twist and hold it in place.
3C0B4650-D6BD-498D-A4BF-AB43A82148AE-161-000000077750ED6F_zps76d433d9.jpg~original
Then after :doh: i started looking for another spot to drill into my light housing.
found this place.
where the drain/vent line is, perfect!
I started by drilling a small hole about the size of a dime, then slowly enlarging and test fitting with the bulb and socket, eventually landed with this much cut out. (notice the side is cut out also)
:rockon: time to test fit on the 4Runner and see how it works.
Then with other lights on: you can see the amber flash from the reflector. but i will change bulbs to amber for better contrast.
Good enough for the girls i date. :party:
Let the :hail: begin.
EDIT: 2,000st post here.
[MENTION=5345]habanero[/MENTION] did this on her own '96 SR5, in addition to adding side markers as well...
I've been meaning to do this for over a year now, and I think [MENTION=85046]nissanh[/MENTION] has also already added this on his '97...
nice.
I did something similar on my 85. except on that one, the plug for the signal, and the marker light was the same. so I just plugged the signal wire into the marker light.
I lost the markers, but I didn't care about that. :D
Thanks for the write up. This is something that I've been meaning to do as well.
I have the LED turn signals in the Outdoor Logic bumper, but they're virtually useless during the day.
I just replaced the stock socket and bulb with a dual filament socket and bulb, all I had to do was bore out the stock location a bit. Makes for a clean install and was super cheap.
nice.
This is what I've done on the 3rd gen. I have the LEDs on my addicted offroad bumper and the side marker lights connected. Used some of the small female spade type connectors instead of the OEM plug. Unfortunately the hyper flash issue still exists so I have a little more work to do. Like you, I rarely use the parking lights.
Care to elaborate? Does this mean you have turn signals and parking lights in one bulb??
see write up linked in quote below, a dual filament bulb has two "lights" so you keep the driving lights and have a turn signal in a single bulb
Nicely done!
I used this yeeeeeeears ago on my '86: Toyota Tech: Turn Signal Relocation
Had to build up the mount though but still works great and is waaaaaay brighter than the OEM ones I had.
Nice! That's what I thought, I just wanted to make sure since everybody seems to do this mod differently... but I think that's the best way. Added to bookmarks, thanks!
No prob, after I installed my CBI tube front bumper I ran some LED turn signals on it but when the time came they wouldn't pass inspection. So I had to find a solution quick, this was the easiest and kept the lights looking stock. Only took me about an hour once I had all the parts
I found this just to be a simple and super cheep way of doing the turn signals that dont cost any money yet still look good and get rid of my zip ties.
oh how the modding never ends. thanks for all the comments guys. didnt know so many people had already done this or had this information on it.
I did the same as the OP. Used clear silicone and grafted the sockets into the marker light housing. Remounted the breathers up at the top of the housing. Clear bulbs for now but I'll look for amber ones when I can
I had the same problem with the leds that outdoor logic provided with the bumper
I found some replacements at harbor freight that have multiple leds instead of just one.
Huge improvement and they were direct swaps.
