Projector Retrofit Picture Thread and FAQ
Yoter
It seems like HID projector retrofits are becoming increasingly popular these days and I thought it would be useful to have a picture thread where people could compare different shrouds and paint schemes etc. I also added some general info about HID's below.
And I am sure it would also be fun for those who worked hard on their retrofits to have a chance to show them off.
Edit: [MENTION=94545]MTD[/MENTION]'s first post included some very useful info that everyone should try to include:
What kind of projector?
Shroud?
Paint used if any?
Halos used?
Very Simple FAQ About HID Lights and Retrofits:
What are HID bulbs?
In Short HID bulbs create light by shooting an electric arc across a salt filled chamber (no filament), when the bulb is ignited the salts melt into plasma, which produces a very bright light.
What are ballasts?
A ballast regulates the power given to the bulb; HID bulbs need more power when first turned on and then less as they warm up. They also require current regulation, which the ballast takes care of.
Is it okay to install HID bulbs without projectors?
Usually the answer is NO, Having HID's in halogen reflector housings is similar to driving around with your brights on all the time. Due to the new position of the "hot spot" of the bulb within the housing it will reflect the light in a different pattern then original halogen bulb was designed for.
You probably will be blinding everyone on the road its inconsiderate and dangerous.
Some 4runner owners (as reported on page 3 of this thread by Steezemcqueen) have had decent results, ie not blinding everyone with using "cut off shields" with hid bulbs without projectors.
What do projectors do?
Projectors focus the beam of the HID bulbs so that you can see further and in greater clarity. They also provide something known as a "Cut Off" this allows you to use HID's with out blinding everyone around you, a cut off can provide a stream of colored light at its focal point many people tune their projectors to get the most color possible. They also give you HI and LOW beam function something otherwise lost with the installation of HID bulbs; Projectors that have this function are known as "Bi Xenon".
Are HID retrofits Legal?
No in short any modification to your DOT approved lighting is illegal and may result in a ticket, accident, injury or death and In California it also causes cancer.
Proceed at your own discretion.
Average Cost?
A quality install using new parts can be done for around $300
The aftermarket HID suppliers have grown and parts can be found now for significantly less cost (as low as ~$100) on Amazon and Ebay while many people have had good results using less expensive HID retrofit kits from Amazon and Ebay it is important to note that usually the quality control/reliability is not the same as going through a specialized retailer.
Resources:
Where to buy:
Most people purchase the needed parts from The Retrofit Source, they have very good customer support and quality parts. The Retrofit Source online: headlight upgrades for all applications
Hid parts can also be found on ebay, Amazon or at junk yards and if your feeling lucky.
Where to learn:
HID Planet is a great forum dedicated to HID retrofits that has boat loads of useful info, a link to their FAQ page is below:
[Read First] FAQ and Useful Links (Work In Progress))
On T4R:
Rickashay
http://www.toyota-4runner.org/3rd-gen-t4rs/102734-rickashays-projector-retrofit-thread.html
BrianSD_42 's Morimoto Mini D2S 3.0 Panorama Halo Retrofit DIY ***Complete Guide***
http://www.toyota-4runner.org/3rd-g...s-3-0-panorama-halo-retrofit-diy-journey.html
BrianSD_42
http://www.toyota-4runner.org/3rd-g...it-97-4runner-project-toyota-4runner-org.html
SQ-MD
http://www.toyota-4runner.org/3rd-g...ctor-retrofit-write-up-experienced-sq-md.html
Bandit Runners
http://www.toyota-4runner.org/3rd-gen-t4rs/101725-bandit-runners-projector-headlights.html
GottaBeTRD
http://www.toyota-4runner.org/3rd-gen-t4rs/80110-planning-my-projector-retrofit.html
(Shoot me a PM if you have a writeup I am missing and I will gladly add it)
Other Sites:
1998 4runner headlight retrofit hid projector write up / review - YotaTech Forums
My FX-R 50W Retrofit with Apollo shourds and Amber XBaLED Halos. I am running 5000k morimoto bulbs currently, but looking to upgrade to a set of CBI bulbs. The paint is the same duplicolor spray bomb that I use on all my stuff.
Guys, feel free to PM me If you are interested in a set, my buddy and I have a business on the side building ret
rofits!
Fresh Pics!!!
Low beams on trail.
mtd-albums-mtd-s+green+turd+build-picture22328-1384372-10151839734347621-923315127-n.jpg
Well its not on a 4runner but this is my retrofit, '04 CBR 600RR. Double halos 4300k HIDs with audi LED mod and red demon eyes.
null_zps6e61c6c8.jpg~original
836145A1-53A4-499E-90BA-39D06E79C2D9-7935-000006682B4136E8_zps987b0ce8.jpg~original
0104C67B-F9D2-4261-8AAC-6FCD0EBF9B51-7935-00000664F778723B_zpsf6f2b50b.jpg~original
EFD16054-2A9C-473D-94FA-0FA2FC48FD97-7935-0000066424E1CDFB_zps05238dc7.jpg~original
How was the install on those?
It was fairly straightforward. I took a long time doing it because this was my first
time doing anything of this sort. It was completely plug and play as far as the projector mounting in the headlight housing and all of the wiring harnesses just clipped in with no issue. I could do it again in 1/4 of the time. Well worth the effort and $ to be able to see better than most vehicles can at night. Not sure if tacomaworld is still offering the 25% off group buy, but that's how I got mine. I spent less than $300 for the new eagle eye clear housings and all the retrofit parts from The Retrofit Source online: headlight upgrades for all applications
This is so BA. Reminds me of the head light in my Acura TL Type S. I loved the lights in that car and you could see everything at night.
So how much for a full set up anyhow?
Blue
Blue
I was in about 320 with shipping for my FX-R setup. And BTW TL projectors are an option for retrofits and are known to be one of the best projectors, but because of their size they are very difficult to install. But that is part of the fun lol!
first of all, there are a lot of options. how does one know what to get? second, does the housing have to come apart? how?
Good point looks like I will be doing one of my over the top howto's for this when I build this next set!
