The Bevo Cheapo Build Thread
Ryanincc
Edit: This is not a serious build thread. Mostly just how Ive made my rig worse after being inspired by the real builds around here :-)
Not original photo but looks identical to when I bought it
At the moment….
Yes that is a Bevo antenna topper
Instead of side marker lights I put on Texas reflectors underneath the door handles.
5 Buck cup holder mod
My $5.00 Cup Holder Mod via O'Reilly's and
6 Bucks iPhone Mount… suction cup kind with a base it came with and screwed in.
Stereo has a USB input for iPods but it isn't a constant source of 12V
Usually plugged into splitter with constant power mod. Pics to follow
My tin snips fit perfectly. I use those things almost everyday with that hard as shit to get off packaging of stuff today
Scissors won't cut it… pun intended
Holds my Bubba Keg (slightly modified) nice, smokes, stereo remote, change and clip on sunglasses
Only one screw… needed one cuz the Keg is big and heavy
Surprisingly, doesn't mess with the passenger much.
Seatbelt is easy to put on and seat will slide fine
My Deckplate Mod… I mean Deck'vent'. Its what I had on hand.
a 4" vent and a 5" sink drain screen
My ISR removal… I would have preferred to have the PVC push-on caps put cap und in first but i had only the screw in's. Painted black with a paint pen.
The vacuum hoses I had to rig a little because I cut the one to the power steering pump too short. No biggie. Painted the "T's" with the same pen since AutoZone was out of black ones
EconoAid (or is it EconoAir?) Throttle Body Gasket installed.
I was just going to put a regular gasket on to get rid of the
Factory "D" shaped one. I saw this for sale for a couple bucks
more and decided to try it. It has these vortex inducing teeth
on it. Cant hurt can it?
Whats with the tag and required sticker? anyone know?
Instructions legally warned me about putting the sticker on
http://www.airaid.com/econoaid.aspx
I have no idea if it helps or not
My Ultra-Gauge setup for custom mpg info. I love this thing.
70 Bucks with rebate and does everything I need
GOTTA have Longhorn headrests covers and floormats
Constant 12V… just ran straight to battery with an in-line 15A fuse in it
Splitter with my rechargeable flashlight, Bluetooth ear piece and console accent light button… also used to charge my phone most of the time its not plugged into stereo deck.
The blue console lighting is awesome at night… just bright enough to see down there but doesn't bother your night vision
Anyone know how to cut down on FM interference
when I switch the splitter on?
Haha, no offense intended, but it kind of looks like a homeless man lives in your 4runner. I'm pretty sure those "vortex" gaskets are marketing baloney.
...and I'm not sure there are quite enough long horns on the truck. Maybe one of these?
When I need to find my toothbrush at night without waking the baby
:confused: :noidea:
Ok I give up, what is a 'Bevo'?
Barely Enough Vinyl Ornamental stickers?
Currently troubleshooting a nagging P0301
I looked the code up for you and came back "too many vinyl stickers".
Take it for what it is worth, but I think the removal of some stickers may help your truck run better. If nothing else though, it will certainly help you with the ladies.
just sayin' ;)
