Bad MPG's - Things to check
JBurt
So this is not a plug for a hydrogen generator or any crackpot ideas. I've been getting 11-13 mpg since I bought my rig. I haven't been in a big rush to fix this since we also have a Prius and we drive that when we go anywhere far away. I know I drive a truck but I feel I should get at least 16mpg's. I think that is in reach.
Anyways there are so many threads out there where people ask why their mileage is bad and everyone says search. While there are lots of good suggestions out there I thought what I'd do here was put links to write ups for things that actually do keep you're truck in good working order. I'll keep this first post updated with current procedures and links. I'll start off with the ones I've done and go from there. Anyone feel free to chime in and add some good input. If you've got a better write up I'm happy to change them. Some may not have links at first. A lot of the ones I used are now gone. Hopefully this will help me and some other people. Too bad 4runners.org is down. There was good stuff on there.
Clean MAF
Change sparkplugs
Change upstream o2 sensor
Clean Throttle Body/Idle Air Control Valve
Compression Test/Leak down test
Replace fuel filter
No write ups because they are really easy.
Replace air filter
Replace PCV Valve (pull out old valve and grommet, push in new)
Check tire pressure
Sludge and a dirty top end can also be a problem. There are a few ways to tackle this:
Seafoam
Brute force
A clogged catalytic converter can also cause bad mpg's and severe power loss. One way to check is to remove the upstream o2 sensor to vent exhaust to atmosphere before the cat and see if there is a power gain. That means you cat is clogged.
Bad fuel injectors are also a cause. Replacing is kind of a pain. There are services like witch hunter that will rebuild if possible for much less than a new oem one. Here is a guide to replacement. Anyone know of a way to test them without pulling them out of the vehicle? You can also put fuel injector cleaner in your gas tank. Seems everyone has their favorite.
Exhaust leaks - you can check by doing the above mentioned seafoam treatment, then when your rig is spewing smoke look under the car to see if smoke is coming out from anywhere else.
After you do any of these you should reset you're ecu. To do that either use a computer or disconnect the battery for 15 minutes. The engine will go through a diagnostic mode for 80 miles or so. After the diagnostic mode you'll know if you fixed it.
You should also add that a bad alignment could be a cause. The types of mods we tend to do play a role as well (lifts, wider, more aggressive tires, roof basket, etc.).
Bad electrical connections could be a cause as well. Make sure to clean the battert posts, make sure there are no inadvertent grounds, all connections are complete, etc. Not sure if the spark plug link says it, but changing the wires is a good idea also.
I kept feeling like there were more maintenance things to do with my rig. Thanks for this! I'm getting 15 mpg average (stock) and want to try to improve it.
Improved MPG
Is your MPG city? Mixed? Hwy? The only other thing I can think of is making sure and calculating if the Air to fuel ratio is correct and you're not running rich...?
Resetting the ECU works for me. I have to do it fairly often though so there is probably an underlying problem somewhere else as well. Just haven't had time to really search for it yet.
This thread 4th post down.
I've given up..... :moping: O2 sensors are the only OEM thing left! but all the write ups say aftermarket ones are garbage. Haven't done a compression test either, but i have plenty of power... @ 12MPG (in city) tops out around 16 MPG (highway / freeway).
:ybrick:
Thanks. I added resetting the ecu. My driving is pretty much all in town except for going out in the desert. 11-13 city, 16 freeway.
It doesn't bother me too much, but if I can get it going better why not. The car runs like a top and doesn't give me any other problems.
That seems about average on here, but other things come into play such as added weight, tire size, tire tread, gearing, etc... Thats odd your still only getting 16 though stock wise... I have a 3" lift and pushing 285/75 r16 and I just got 17.1 all highway driving from Iowa to Michigan this past weekend...
Thanks for this. I just notice my mpg's went down. I've done new plugs and cleaned the MAF. I'm thinking its time for a fuel filter, cleaning the IACV, and a new O2 sensor.
Weather is an important factor as well. Cold air uses more fuel. Hot air generally means more a/c usage. Winter gas is a real you know what and terrible for MPG. There could also be aerodynamic anomalies, like if one removes the skid plate or starts driving with the windows down.
updated. My rig isn't stock. I've got a 3" lift and 32'S. Like I said I'm okay with the mileage, I just think it could be a little better. Alignment is a good one.
Wow thank you so much for posting this! I'll be dropping some money into most of these. I get about 15mpg, of course i'm on 285/75/16's. but still! I want the most I can get!
When these trucks were new and completely stock, they were rated at 15 MPG city, 19 MPG highway. At least that is what my '97 V6, 4wd, 5speed was rated at.
Back then Ethanol in gas was rare. Now, it's required by federal regulation. Ethanol has less BTU's than pure gas, so gas mileage drops from what these trucks were rated for, just due to the fuel alone.
Bigger, heavier tires with more aggressive tread than the mild all-season tread these vehicles came with, further hurts MPG.
Lifts, bumpers, roof racks, etc. hurt the aerodynamics, resulting in another drop in MPG.
Adding weight hurts MPG.
Cold ambient temps hurt MPG. The engine is colder, so it takes longer running in fuel enrichment mode, until the engine reaches operating temp.
All of the various oils in the drivetrain are thicker when cold, creating more drag.
Cold air is denser, so it takes more power just to push the truck through the air.
Lower elevation air is denser than high elevation air. So even though the engine makes more power at lower elevation, it also takes more gas to push the truck through the denser air.
The engine becomes a little tired after years of running. Valves may not seal as well as they once did, rings might let a little more combustion pressure past them, cams wear, sensors (think O2/ AF sensors) become lazy but don't completely fail, all of which hurts MPG.
Anyway, all of those factors can add up.
I'm gonna go out on a limb here and suggest that most efficiency problems are rooted in alignment, tire condition, and proper inflation... or weather.
Those factors absolutely contribute to vehicle efficiency.
Another big factor I didn't mention is how and where the person drives. Driving on a trail in low-range 4wd, 10 MPG might be good. Cruising down the highway on a warm day, doubling the trail driving MPG isn't hard.
I'll say my biggest change was replacing the O2 sensor, and cleaning the MAF.
I also have a wideband O2 sensor for monitoring the supercharger (which is obviously standalone), and I've watched how with a new O2 sensor, the engine would sit right at 14.7 AFR's... over time, I've watched that slip down to an average around 14.3, and its still going down.
Then there's the debate about which sensor is actually fouling, but the point remains...
I still manage 17MPG on pure highway, and 14-15 average lately on the winter fuel.
