Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 01-27-2014, 09:51 AM #1
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
LED Dash lights FAQs
My rant; I'm getting tired of seeing the exact same threads pop up almost every week asking about bulbs sizes, differences in bulbs, where you can get them, and why aren't they working. Hopefully this thread will shine some light on these issue, and maybe we can reduce the number of interior LED questions that come up on a weekly basis.
First off, don't assume you have the correct bulbs on order. Check your vehicles bulb sizes on the chart below. This chart when help insure you're getting the correct bulb size for your year and model.
I'll use my 2001 as an example.
You need to remove the center section of you console. I'm not going to explain how to do this since most of you should already know how.
I didn't take a picture of this but the shifter bulb is on the wire in red, and bulb is located around where the yellow is. Just turn it counter clockwise and pull it out. (#74 LED)
Next, pull the knobs off the climate control, and also remove the cover plate. They both should just pull right off, nothing tricky about it. Take out the 3 screws marked in red and disconnect the 2 plugs in the back.
Remove the three screws in red and remove black cover.
Remove the 3 bulbs marked in yellow. No need to remove the 4 screws marked in red unless you have issues with the bulb to the far left. (NEO4-W)
I then replaced the ECT and rear window LED's. Remove the 2 bulbs marked in red (might be difficult to get out). NEO3-WHP
I started by removing the lower part of the dash. The screws I had to remove are marked in red.
Next I removed the section that's covering the key ring. I gently pulled in te bottom right corner to get it loose.
Once the cover is off there is a small white plastic pin thingy that holds the surround on, pull it out. Once it is removed you can slide the surround off and change the bulb (sorry no picture). (#74 LED)
Remove these two screws to loosen the trim around the instrument panel itself. Pull aside.
Remove the four screws and disconnect plugs to remove the instrument panel.
Now remove these six screws to be able to access the bulbs (bulbs are in yellow). I used #74 bulbs for the 2 blinker bulbs.
The two lower yellow squares are for the blinkers. (#74 LED)
The far left, far right, and upper middle yellow squares are for the speedo, tach, and 4wd. (#24 LED)
Used these for the speedo and tach bulbs.
The bulbs that I used where all from Super Bright LEDs. They have good pricing, and usually ship all orders the same. The bulb sizes I have with the pictures are clickable links, and will take you to what I purchased.
Here are some other LED threads for information:
@sn0wrunner - LED Lighting
@Brilliant - Brilliant's Mod Thread
@shootmymime - WRITE UP: climate control and dash bulbs 2000 limited
For the map lights I used the BA9S bulbs that I found on eBay.
For the dome lights I used some Festoon Sockets and 12SMD led panels from eBay.
If anyone wants to contribute their LED swap let me know and I'll add your thread.
Hopefully this helps.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 11:43 AM #2
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
But what about the flux capacitor?
J/K, great job with the illustrations. Now if you make this thread a permanent link at the top, we won't have to answer the same questions 40 times a week right? Nope, someone will still ask.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 01:43 PM #3
TheeMikeB's Avatar
TheeMikeB TheeMikeB is offline
TheeMikeB is on a distinguished road
TheeMikeB's Avatar
Well done write up and this will hopefully clear some things up. I know it certainly did for me AND I have an 01 too so I will def use this.
One thing... I don't see the yellow highlights you are mentioning in the post about the ECT and rear window LEDs.
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
TheeMikeB is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 01:48 PM #4
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Edited to say red. Thanks
Old 01-27-2014, 02:01 PM #5
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
looks a little familiar, but good thing you did it with a slightly different 4runner.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 05:34 PM #6
SR5Runner97 SR5Runner97 is offline
Real Name: Alec Thompson
SR5Runner97 is on a distinguished road
Also, my 97 4runner sr5 has 31mm in the map lights. I bought ba9s but then took it apart and it wasn't them. Oh well!
99 SR5 4Runner 3.4l
Factory elocker with 5 speed
265/70r17 terra grapplers
SR5Runner97 is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 05:51 PM #7
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Thanks, forgot about that one. I added a link the BA9S bulbs that I bought on eBay. I also put up links to the bulbs I used for the dome lights.
Old 01-27-2014, 06:05 PM #8
snivilous's Avatar
snivilous snivilous is offline
snivilous will become famous soon enough snivilous will become famous soon enough
snivilous's Avatar
Awesome, thanks for putting this together
One question: Aren't all the round black pieces on the top of the this picture (bottom of the dash if you were looking at it in the truck) lights? Don't you need to replace those? I don't see a large number of #24 or #74 or whatever in the spreadsheet photo saying how many are needed for all of those or what size they are, though maybe I'm just missing it.
Originally Posted by MStudt View Post
snivilous is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 06:20 PM #9
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Yes, those are all bulbs. You can replace them if you want to spend the money on it. I just replaced the bulbs that were used on a regular basis. I didn't feel the need to have an led bulb for the check engine light, and so on.
Old 03-19-2014, 05:39 PM #10
Brique's Avatar
Brique Brique is offline
Brique is on a distinguished road
Brique's Avatar
Pure win. Thanks for this. I'll be using it within the next couple weeks.
Brique is offline   Reply With QuoteReply With Quote
Old 03-19-2014, 06:51 PM #11
Stuck Stuck is offline
Stuck is on a distinguished road
Excellent write up, I used the same brand for my swap. Thing to note - superbrightleds #74 cool white has a slightly different thickness than the colored #74 red, blue , green. The 74-chwp may not fit in all holders.
The picture shows the cool white facing left <- and a blue facing right -> . Notice the difference in thickness. The electrical connections don't make contact .
I can say for sure the cool white does not work in the shifter on mine, the blue works fine.
It works on the ignition - fine though.
LED Dash lights FAQs-image-jpg
Stuck is offline   Reply With QuoteReply With Quote
Old 03-20-2014, 02:00 PM #12
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Thanks for this effort Mike-superb! Now I just gotta decide on what color to use!
Old 03-20-2014, 03:37 PM #13
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Does the dimmer still work on these bulbs ? If it's to bright at night ?
kolelt is offline   Reply With QuoteReply With Quote
Old 03-20-2014, 03:45 PM #14
MattAK's Avatar
MattAK MattAK is offline
Real Name: guess..
MattAK is on a distinguished road
MattAK's Avatar
Real Name: guess..
I did this last year. Dimmer works fairly well. They'll go dim until there's not enough power then they shut off. So the dimming range isn't as good as the regular bulbs but still more than enough for me at night.
'08 V8 Sport Galactic Gray
'16 TEP Magnetic Gray "Kylo" - SOLD
'01 SR5 Thundercloud Gray - SOLD
'94 SR5 Dark Blue Pearl - SOLD
Originally Posted by RysiuM View Post
I just look at them and say: you have no absolutely slightest idea what are you talking about. This is 4Runner.
MattAK is offline   Reply With QuoteReply With Quote
Old 03-20-2014, 10:56 PM #15
What type of led do u get ? There's few different options. Like 5led bulbs or single led.
Dash Lights Are Out... wantahertzdonut Classic T4Rs 10 03-24-2013 02:07 PM
Tail Lights, Markers, License Plate, Dash Lights all out! aeroneer1 3rd gen T4Rs 3 09-01-2012 06:53 PM
Dash Lights Failed. Running Lights Work. CanadianTRD 3rd gen T4Rs 4 08-14-2012 11:10 PM
Dash Lights and Tail Lights Out chaossd 4th Gen T4Rs 1 01-03-2009 07:20 AM
leds in tail lights, no brake lights, buzzing from dash with blinkers??? jamr1 3rd gen T4Rs 0 09-12-2008 07:10 PM
