My 98 Limited
busmup808
Introducing my 1st 3rd gen. Not new to Toyota, but built a whole lot of Hilux/Runners/Landcruiser in my life from geared, locked, SAS, duals, etc.
Originally From Oahu, HI and moved to WA. New beginning to make new memories. Now on to this T4R, bought this truck last Thursday and been tinkering with it since.
ENGINE
3.4 V6 stock
TRD 1ST GEN BLOWER
URD ALUMINUM CRANKSHAFT PULLEY/2.2 PULLEY
URD billet crankshaft pulley
295cc (6pcs) injectors
Deckplate mod
TRD HEADERS (MODIFIED)
Big 6 Wire Mod 1/0 AWG OFC
GENUINE TOYOTA Alternator
COLOMBIA OVERLAND dual battery tray
2 ODYSSEY ODY35-PC1400T
IBS Intelligent Dual Battery System
IBS Relay Booster Module
INJEN IS300 modified cold air intake
OEM TEQ oil cap
REDARC1225D
SUNFLARE 105W Solar Panel
OVERLAND SOLAR 130W Solar Panel
TJM HD compressor
TRANSMISSION
5 SPEED R150F
MARLIN CRAWLER MC31 MC09 4.70:1 COMP GEAR KIT(pending)
WHEELERS OFFROAD HEAVYDUTY CRAWL BOX RF1A (pending)
RADesigns triple sticks (pending)
Brass 2.56 H N, 4.7, & 2WD/4WD (made by me in the shop) (pending)
EXHAUST
Hi Flo CAT
BORLA exhaust
SUSPENSION
F/R FAB WORK WAS DONE BY OUTLAW OVERLAND IN WA
F SAS 3”TG LEAFS TG LH DROP HOUSING
YOTAMASTERS 8” LONG SPLINE KIT
DRIVELINES NW driveshaft
NITRO 5.29 GEARS
ARB AIR LOCKER
MARLIN CRAWLER 6 STUD HIGH STEER/25MM STEERING PIN
TG 6 SHOOTER KNUCKLES
BOBBY LONGS AXLES
FRONTRANGE OFFROAD big brake mounting kit 231mm
FOX RESI SHOCKS 12”
R SLEE OFF ROAD 6” FRONT FZJ80 COILS
(FACTORY 4LINK DELETE) 3LINK W/1.25HEIMS
STOCK DRIVESHAFT
NITRO 5.29 GEARS
STOCK E-LOCKER
FOX RESI SOCKS 10”
R ROCKJOCK Antirock Sway Bar
R Adjustable panhard bar .875 HEIMS (MADE BY OUTLAW OVERLAND)
R panhard extensions (MADE BY OUTLAW OVERLAND)
EXTERIOR
teq front badge (made by me in shop)
01 Tacoma front clip conversion ($566.96 local junk yard)
01-04 Tacoma Genuine Toyota Headlamps (Morimoto D2S retrofits)
01 GX470 horns
Led marker bulbs
Clear DEPO blinker lamps
Genuine Toyota Marker Lamps
JDM HDJ81 Amber side marker lamps
SHERPA EQUIPMENT CO: THE MATTERHORN MKI
FRONT RUNNER: QUICK RELEASE TENT MOUNT KIT
IRONMAN:Quick disconnect awning bracket
TJM: YULARA RTT
TJM: Annex
TJM: 2.5M Awning
UpTOP OVERLAND scenePOD 6
BAJA DESIGNS ROCK LIGHTS 6
INFINITE OFFROAD RGB+W ROCK LIGHT KIT 10pcs
91 FJ80 rear license plate holder on tire carrier
CBI driver antenna bracket
JDM Hilux Surf 4Runner Window Visor
Tacoma Safari Snorkel
04 Lexus GX470 rear camera for the front
06 Prius OEM rear camera
01 Taco Whip
JDMHilux Surf L fender mirror
JDM Hilux Surf LED L/R mirror covers
JDM Hilux Surf Mirror Wing
JDM Hilux Surf DEPO Smoke LED Taillamps
Sonoran Steel Polyurethane Body Mounts (Pair)
CUSTOM Aluminum fold down table
CUSTOM Aluminum CO2 20lb bracket
CUSTOM Aluminum 7075/6061 extension brackets for modular system (made by me in the shop)
INTERIOR
04 GX470 Steering wheel
04 Tacoma 60/40 split seats Tan cloth
98 Stock rear leather seats w/97 LX450 tan leather headrests
14 ES300 tan leather over head hand rests(front row)
04 GX470 tan leather over head hand rests (2nd row)
Clarion MAX675 DVD/CD headunit
CHAMELEON 7" headrests 2PCs
F speakers MB Quart 6.5" separates
R speakers MB Quart 4" coax
F amp Precision Power 4cha
R sub amp Rockford Fosgate Power 200.1
JL AUDIO W3V3 6.5 SUB
07 FJ100 Black Leather shifter
99 head console swap ($10 local junkyard)
99 rear cargo storage swap. ($10 local junkyard)
BLUESEAS 12 fuse block (front)
BLUESEAS 6 fuse block (rear)
BLUESEAS Dual USB charger (1front &1rear)
VIAIR 380C compressor
UNIDEN PRO 510xl
Beat-Sonic BC1SUS
Lo-Tek, Inc dual gauge pod
Victron Energy battery monitor BMV-700
RAM MOUNTS X-GRIP
MSA 4x4 Seat Organiser Drop Down Table
JDM Hilux Surf Field Monitor Unit
JDM Hilux Surf 3 din console
JDM Landcruiser Prado 96-02 Digital Compass Clinometer
BH3D F side double cup holder
CUSTOM 3 cup holder, coins holder, pen slots (made by me on PRUSA 3D PRINTER in shop)
CUSTOM Wood/Aluminum Drawer System
ARMOR
BADLAND: Winch Bumper
BADLAND: Spare Tire Rack System
BADLAND: Sliders
LOWRANGE OFFROAD Toyota Electric E Locker Motor Guard (TDI-ELMG)
4x4LABS Ladder attachment
Metal-tech 4x4 Red Eye Utility Rack w/ licence plate holder/Fuel Can Holder
RECOVERY
Smittybilt Comp-Series XRC 8 Winch
TJM Ox Snatch Strap 17,600LBS
TJM Snatch Block, Heavy-Duty, 22,000
TJM Tree Saver Strap, 22,046 lbs.
TJM Tire Repair Kit
CM Shackles 6.5 ton (2) on F/Bumper
FACTOR 55 ProLink
FACTOR 55 2.0
CM Shackle 6.5 ton (1) on rear
TELAWEI 4x4 EXHAUST JACK
TRED 1100 4pcs
CAMPING
Greensport Camp Kitchen Untensil Set
Scepter Military Water Can 20 L Olive Drab
Scepter Military Gas Can 20 L Desert Sahara Sand
5pc Acu Camouflage Improved Modular Sleep System IMSS MSS USGI Sleeping Bags w/ Bivy (2 systems)
Polish Sleeping Bag/Blanket Roll Carrier
TREKKING OASIS aluminum table
DISCO BED Cam-O-Bunk
TJM OFFROAD Camp Chairs 2
WATERPORT 20L
INSTANT AIR SUPPLY: 20lb Co2 On Board Air System
FRONT RUNNER 40L Footwell Water Tank
KARIBA Ranger 4X4 Dual Burner Hot Camp Shower and Cooker
10lb Propane Tank
POWERTANK Aluminum Propane Bracket
ARB 63qt Fridge/Freezer
ARB 63QT TRANSIT BAG
ARB FRIDGE REMOTE MONITOR
MSA DS60
RIMS/TIRES
5 17x9 HUTCHINSON DOT BEADLOCK
5 COOPER STT PRO 37X12.50R17
DAY 1
CURRENT of October 5, 2021
When you click post reply go down to the manage attachments and then you can add them when it opens in a new window
I did it from downloading it to my photobucket, then copy and paste to here. I'm using Tapatalk and it's hard to do. Gotta have a simpler way. Still learning.
As Mike Tyson exclaims in The Hangover, "Nice!" Quite clean.
Welcome. Here, we help you quickly spend your birthday money.
Wow. Clean looking truck. I'm jealous. Welcome aboard.
Thanks! The only reason I'm keeping it clean is to stay IFS. Comfort and less hard lines will keep it a beauty. If I start cutting/grinding/welding, I'm going to bust it like my past rigs.
Where are you in WA? Vancouver here! I see an exhaust tip, does it have an aftermarket exhaust?
I'm 15 minutes away from Puyallup Fair grounds. The exhaust was done by PO, it's an Tundra from the muffler back. Don't know if it's helping or hurting my MPGs.
I'm 15 minutes away from Puyallup Fair grounds. Don't know if it's helping or hurting my MPGs.
If you wanna drive 2 hours south then i'll take you where i go wheeling! I can't imagine it being the main source to bad mpg. Does it sound different? Stronger?
Also, those hellas look so clean where you put them. Are they used as offroad lights or fog lights? i would assume fog but then they are covered. you have a link to what exactly they are?
The Hella were done by the PO. Currently not working, but I didn't even get into it. I think it's just a bad relay. Well I hope it's just that. The lights are fogs and are covered all the time. T4R has always been garage kept. That's the reason for it's Cleanness.
I also forgot to add the T4R came with the Tan Husky liners from front to back. They were fricken gross though. Had grease and dirt top/bottom. Got on my hands and knees to get them cleaned. Took me a good hour.
While my 4 yr old took his nap, I installed the 99 R rear larger storage compartment. Took me 45 min from start to finish. My original oak panels were all scratched up from the PO dog. These tan panels have no scratches at all from top to bottom. The rear looks brand new. I was looking at the colors when I finished the install, Toyota should of made it tan from front to back. I also had to cut the rear sheet metal to make it the lenth of the bigger opening. For the life of me, i miss placed the tan cig thingy. Had to put the oak untill I get another tan one.
90 Toyota Odyssey RV
91 Toyota Landcruiser: Built with a lot of JDM
85 Toyota xcab SR5
Last is my 1st truck when moving here is a 86 Toyota 4runner.
Well I got my Hella fog lights to work. All I did was change the bad relay. Not much, but it's all I could do because my 4yr old got sick. :( At least it's working now.
Well, I just got done finishing the Tundra 13WL on my 98 T4R. Found a 06 Tundra 2 hrs away from me with 30 original miles. Guy wanted $120 for calipers and rotors. Packed my 4yr old and went for a drive. Just bought the pads new and resurfaced the rotors. Tech guy told me the rotors were new and I just smiled. Bought some paint, but the damn thing sucks. That took the longest time. Well here it is and enjoy.
