What do you keep in the rear cubby?
GrampsT4R
Just got my 4runner. I have two emergency kits that I need to carry but they won't fit in the cubby in the trunk area on the right. Looking for ideas for stuff to store there.
Post em up!
Planning to get myself a mechanics toolset, probably in parts so it isn't one big case. Screw drivers/flat heads in one and wrenches/sockets in another. And then down the road invest in one of those Stanley jump start/air compressor. Always good to have, and I'll need an air compressor eventually anyway! Kill 2 birds with 1 stone. (yeah I know it won't fit there, but the tools will.)
Cheapo machette from Walmart camping section fit (tight) angled in there. Put a large snatch strap rolled up, and then filled in the remaining small spaces with some ratcheting straps. Nothing seems to rattle or vibrate currently, granted it's a tight squeeze with all that stuff.
Plastic dog water bowl
Tennis ball
"Power braid" rope
Various socket sizes and a ratchet
Flathead screwdriver
Emergency triangle (what that rack mount is made for); 6V Lantern, 3 Flares, Box of assorted fuses, Mini-First Aid Kit with bug juice and sunscreen.
I keep a Roll of TP in there, jumper cables, ratcheting straps, small flashlight, gloves and gallon of coolant. I should probably take out the coolant, and look for a first-aid kit.
The 99+ guys have more space in their rear cubby... I wish I had more space there!
A Trail Gear Tire Repair Kit:p
Fits tight but it is perfect. Works SO Well
and a couple of other trinkets (fuses etc...)
Mini folding chair
Metric socket set 6pt. 8-20 shallow
Metric socket set 6pt. 8-20 deep
Bag of tools;
Standard long screwdriver
Standard stubby screwdriver
Phillips long screwdriver
Phillips stubby screwdriver
multiple lengths (3", 6", 10") socket extensions each in 1/4", 3/8", 1/2"
utility scissors
needle nose pliers
bent needle nose pliers
6" adjustable wrench
8" adjustable wrench
magnetic flashlight
The cubby is for most of my oddball stuff and accessories for my ratchet set which sits on the floor under a 24 pack of water bottles and a utility blanket.
Built a storage box to hold: ratchet / sockets, screwdrivers, crescent wrench, recovery gear, spare fuses, duct tape, boots, towels, a shovel, gloves, a hammer, a hatchet, 200ft of 200lb test rope, ratchet straps, tire chains, saw, paper towels, climbing caribiners, spare electrical wire, electrical tape, spare headlight bulb, and other misc. stuff. Beside my storage box I have a Rockford Fosgate amp/ 12" sub w/ enclosure, a small cooler, 2 gallons of emergency water, and a bug out bag.
With the smaller cubby in my 97 there isn't much room to jam stuff in there. I believe that I have jumper cables, a quart of oil, a first aid kit and some rags stuffed in there to stop any rattles.
A cargo box build is in my future to clean up all the random stuff (tools and recovery gear mostly) that fills up the back of my buggy.
