Energy Suspension Sway Bar bushing part numbers?
Are these the right parts for front and rear Sway Bar bushing on a 2000 4runner?
Energy Suspension 9.5165G 1-1/4" Greasable Sway Bar Set
Energy Suspension 9.5161G 1" Greasable Sway Bar Set
I searched the forum and I am still not sure if I order the right parts.
Thanks
Frank
http://www.toyota-4runner.org/3rd-gen-t4rs/145817-anyone-have-prothane-bushings-notice-2.html
I have a 2001...that said here is some info for you
check page 2 someone went through it all...
check the delivered price from amazon and from energysuspensionparts.com I went directly through energysuspensionparts.com and saved about $10 delivered
I actually just placed my order...got black because black is graphite infused and self lubricating, hopefully that aspect works out.
for rear:
9.5156 Universal - Greaseable Sway Bar Bushings 3/4 in / 19mm $15.99 1 $15.99
Color: - Black - -
for front:
9.5161 Universal - Greaseable Sway Bar Bushings 1in / 25mm $15.99 1 $15.99
Color: - Black - -
my entire order is as follows, from everything I have read and researched the last few days this will really help the steering and the ride...
Details Name Unit Price Quantity Total
9.8105 Sway Bar End Link Grommets and Washers - 98105 $8.99 1 $8.99
Color: - Black - -
Color: - Black - -
Color: - Black - -
8.10103 Steering Rack Bushings $16.99 1 $16.99
Color: - Black - -
Sub Total: $57.96
Shipping: $8.99
Grand Total: $66.95
ha you had me freaked that I ordered the wrong stuff so I went and measure with an adjustable wrench to get the exact diameter...the front is 25mm or just about 1" and the back is 19mm
I think the 1.25" or 33 mm is going to be too be big
so as I said you want the following:
front:
Energy Suspension 9.5161 Universal - Greaseable Sway Bar Bushings 1in / 25mm Made by Energy Suspension
back:
Energy Suspension 9.5156 Universal - Greaseable Sway Bar Bushings 3/4 in / 19mm Made by Energy Suspension
I added these two just to complete the poly bushing fury I was on I really think they will help...
Energy Suspension 9.8105 Sway Bar End Link Grommets and Washers - 98105 Made by Energy Suspension
Energy Suspension 8.10103 Steering Rack Bushings Made by Energy Suspension
Good luck! hope this helps!
Energy Suspension 9.5156 did not fit OEM sway bar mount
front:
back:
Resurrecting this thread because I referenced it when purchasing poly bushings for my 2000 4WD T4R. I purchased the exact list above because I liked the idea of greasable sway bar bushings. The OEM ones came out fine but I noticed the bracket on the new rear sway bar bushings was larger than the OEM ones. The bushing hole diameter was correct, but the holes on the bracket were just a little too wide and the OD of the bushing was too big for the OEM bracket. When installing it put a weird side load on the bolt when torquing it down and the bolt broke...F! I ended up having to drill it out and then grind out the bracket hole to fit the OEM mount. I haven't done the front sway bar yet, but if I'm tempted to return the Energy Suspension universal greasable 9.5161 and go with their 8.5141 but I'm not sure if the bracket is any different. Has anyone had this experience? Do the 8.5141 bushings fit the OEM sway bar bracket/mount? This ended up being a way bigger PITA than it should/could have been.
Are these the T4R specific sway bar bushings for OEM bars?
Rear Sway Bar Bushings - Toyota 4Runner - 8.5142
TOYOTA 4Runner Front Sway Bar Bushings - 8.5141
