For the 2wd guys: Put a 4wd auto shift handle on
dgoll75
First off, thanks to DeathCougar for the parts! Ok guys so I know that maybe it seems like a silly mod, but its something I have always wanted to do. Did a ton of searches about trying this on all the relevant forums and found nada. Looked like it would be swapping a couple screws and a spring or two, easy right. NOPE. 2 hours later, and a bunch of work and VOILA! Had to cut 50mm off my stock shifter and its interior parts, tap some new mounting holes, re-thread the pushrod, shorten the trigger spring, and rewire the O/D button. So if anyone had this in mind BE AWARE its kind of a PITA. Turned out really cool though and it looks like it came from the factory this way.
Awesome MOD [MENTION=64040]dgoll75[/MENTION], I bet there are some people out there that will really appreciate your hard work. :tea:
no pictures of the end result?
I guess I'm confused because I expected to see a 4HI/LO shifted added. What exactly did you do? I have never actually been inside of a 2WD 4Runner so i don't get it.
BTW faking 4WD is highly highly offensive. :fear:
The actual shift knob is different, kinda big and ugly.
I tried doing this once years ago. I didn't get it to work as well because I didn't do any modifications. Looks good to finally see it done. Swapped a 5-speed a couple years ago so that never had a chance to materialize again.
I still have that 4WD shifter and I'm going to try to fashion it into my girlfriends 99 Limited. Thanks for the inspiration.
Not faking a 4wd by any means. As Mike&Ike said the OEM 2wd shifter is huge and clunky. If my intent was to fake a 4wd, I certainly could have mounted the tcase shifter along side.....
Thanks bro for the hard work. I have been wonting to do this since I got my runner and by the way i have the same cup holders mounted on both sides of my shifter.:D THANK YOU
My 01 Tacoma Prerunner had the same lever. It was also 2wd. It also had 4 stationary cupholders.
Went from this:
images
To this:
:moping:
nice job, that looks way better than the giant bobblehead that comes in the 2wd. if you can do all of that, then a 4x4 swap should be a cake walk...
I'll be honest, when i read the title i was thinking "that sounds stupid".
After reading the thread, I'm pretty sure I'd want to do this too if i had a 2wd I was planning on keeping.
Well done!
Well done!
Thanks bro. Its my DD for my Mobile Detailing biz which I carry a trailer for. No need for 4wd. But I love it anyway... :bigok:
I was actually thinking about swapping to the 2WD style handle. I always liked resting my hand on top.
I couldn't think of a feasible way to do it without me getting really angry. So I'm sticking with the stick style shifter. :rofl:
To go the opposite way I think it would only require the swapping of a couple screws and springs. Reason I had to cut the stock 2wd shaft is because the 4wd handle is taller. Would have hit my dash.
I have a 2wd, I bought it to use as a DD for the next year or so. I plan on turning it into a rock crawler at some point.
I will eventually use a 4wd shifter and move it over to make room for transfer case shifters.
Right now this is all talk, but I get excited seeing pictures of mods like this. Makes me want to make some money so I can buy ANOTHER 3rd gen and get started with my build!
I better pay some bills first :phone:
